New "G" springs in my Record shifter didn't work well
Old 08-14-09, 12:21 AM
gearbasher's Avatar
Quoted: 452 Post(s)
Liked 904 Times in 383 Posts
I replaced the G springs in my right (rear) Campy 9 speed shifter. Originally, it shifted fine in the top 5 cogs, but on the smaller 4 cogs there was no distinctive clicking sound when shifting in both directions. Plus, it felt "mushy" while shifting through those gears. After replacing the springs, when I shift from through the gears from the largest cog to the smallest it feels like a brand new shifter. But, when I'm shifting in the other direction, it feels "mushy" in every gear and there is no distinctive click in every gear. What gives? This is the fourth lever I've done and I've never had this problem.
gearbasher is offline
Old 08-14-09, 02:28 AM
cs1
cs1's Avatar
Bikes: Specialized, Schwinn
Quoted: 225 Post(s)
Liked 24 Times in 22 Posts
Depending on mileage, you might need a new Ergo gear. The notches in the Ergo might be worn more on one side. If you replaced the springs you'll see it's no big deal to do the gear. Good luck
cs1 is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
