replacing front Deore derailleur with unusual clamp?
Bikes: (shortlist) Cyclops, Marinoni, Mariposa, Air Firday, Pocket Rocket Pro, NWT, SLX Fuso, Claude Pottie (France) x3, Masi Team 3v, Lemond Zurich, Bianchi OS
Quoted: 167 Post(s)
Liked 33 Times
as a result of an accident, I have broken my girlfriends front derailleur cage on her very precious Specialized.
I thought it would be a simple matter of swapping the front Deore derailleur.
Surprise. I've never seen a derailleur mount like this before. Instead of being clamp on or a bolt on flange, it seems to affix to a post and a bracket that goes around the bottom bracket.
Can anyone advise me as to:
a) what kind of mount or derailleur is this?
b) is there anyway to just replace the cage?
c) what would I search for if I were to look for a replacement?
(and d) why in goodness name did any manufacturer allow something so non-standard on their bike?)
thanks
Peter
thanks
Peter
Bikes: Hecklah
You don't just replace a front derailleur cage. You replace the whole dang derailleur. No matter what type. I don't know where you could just buy a cage.
What you've got there is called an "E-Type" front derailleur mount.
You remove the BB from the drive side, slide the derailleur off, and replace.
Quoted: 167 Post(s)
Liked 33 Times
Presenting "Lowki"
When Julie bought this bike, some years back, she thought the original red black and white paintjob looked like a Coors Light beer can. and that was not a good thing.
so, being the frustrated artist she is, she broke out the paints.
https://picasaweb.google.com/TOcycles/Lowki#
Peter
Peter
Just a FYI after you get the ORG one off, you should be able to install a regular clamp on model. You just need to find one that will fit the seat tube, or get one that comes with spacers. I had one of those on my Old Fisher Wahoo, ended up upgrading to a clamp-on, I was told I probably shes a 1/4 lb by ding so.
Now after seeing more pics of the rig. I am no bike tech, but you may have to go back with the same type. A clamp on may not work with that frame. But again I could be wrong.
foolishly delirious
looks like you wouldn't have to take BB apart...
that 'bracket' looks like a 2 piece... might have to buy the whole thing... but looks like (in pic #1) that you can unbolt the bracket from the top part (derailleur) and slip it right back on...
Quoted: 167 Post(s)
Liked 33 Times
leave the bracket
this appears to be correct, as I have just unbolted the main derailleur body from the bracket. once I find a replacement, I expect the spacing should be standard enough that I can bolt it back on without having to remove the crank arm etc. etc.
Peter
Peter
Addicted to Dirt
Bikes: Stumpjumper Comp 09, Nishiki Prestige (1990)
35$ for an XT on a slightly older model. Going on an older bike there's no need for the latest and greatest.
Edit: Whoops. Sorry didnt' read close enough but it's out of stock. Regardless, just google e bracket front derailleur and you should get lots of results. FDs are relatively cheap and with little performance difference so you should just look for a deal.
