Taking off these damned cranks?!
Old 08-17-09 | 11:02 AM
NYC_zx10's Avatar
I Need Intervention
I feel like an idiot asking this question but like all in life, you learn from your mistakes (or stupidity, haha).
I'm trying to take the original Shimano 105 cranks off a Miyata 310 I picked up this weekend.
I took off the 13mm nuts and cant for the life of me slide the cranks off. I've tried oiling them up and nothing. I really didnt want to start hammering away at them and risk scoring them.
Am I supposed to be using a puller to get these off ?
NYC_zx10 is offline
Reply
Old 08-17-09 | 11:10 AM
15 Anniversary
Yes.
sciencemonster is offline
Reply
Old 08-17-09 | 11:13 AM
miamijim's Avatar
Sheldon Brown Memorial - Donating
20 Anniversary
Yes.
miamijim is offline
Reply
Old 08-17-09 | 11:16 AM
unworthy1's Avatar
Stop reading my posts!
20 Anniversary
Community Builder
+3, yes...and to add something *helpful*: since these are nutted you'll have the best luck using a Maxi style crank puller, instead of the standard style that works best on cranks with bolts. If you don't want to buy a crank tool, go to your LBS (one that has a Maxi puller) or ask around to borrow one, locally.
unworthy1 is offline
Reply
Old 08-17-09 | 11:27 AM
noglider's Avatar
Titanium Club Membership
15 Anniversary
Community Builder
Community Influencer
Or have the LBS remove them for you for a small fee.
noglider is offline
Reply
Old 08-19-09 | 12:57 PM
NYC_zx10's Avatar
I Need Intervention
So I got the left side off with a puller.
I cant get the gear side off. Ive tried, and tried, and i just cant get the puller centered to be able to get it off squared.
Any tips?
NYC_zx10 is offline
Reply
Old 08-19-09 | 01:05 PM
Chombi's Avatar
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Uhhmmm.YES....puller needed, for sure....
That's why tapered, square ended bottom braket axles and square holed cranks replaced the old cottered crank systems...so they don't get loose and slip off so easily...or not come of with....uhmmm....banging a hammer on them, for instance.;^))
Chombi
84 Peugeot PSV
Chombi is offline
Reply
Old 08-19-09 | 01:09 PM
NYC_zx10's Avatar
I Need Intervention
This is on an 86 Miyata.
It has the square ended BB axle. Cranks are square holed also.
Strange that the ones on my Univega slip right off/on but these are on TIGHT. Ive soaked it for 2 days in PB Blaster and cant get it to budge.
NYC_zx10 is offline
Reply
LesterOfPuppets's Avatar
The space coyote lied.
15 Anniversary
Community Builder
Bikes: everywhere
The drive side is a little tricker, since the top elevation of most drive side crankarms presents an angled edge, so that when the puller's in straight, it doesn't look straight.
Get a soft wire brush (or substitute a toothbrush) and clean the threads of the crank and crank puller, keep trying gently to get it threaded in there.
LesterOfPuppets is offline
Reply
Old 08-19-09 | 01:37 PM
Geesh.
https://www.parktool.com/repair/readhowto.asp?id=103
Old Fat Guy is offline
Reply
Old 08-19-09 | 01:44 PM
treebound's Avatar
aka: Mike J.
Bikes: 1995 Trek 520 is the current primary bike.
Just a silly question but is there a washer still inside the pocket? Sometimes washers hide well, and sometimes someone slipped two thin washers in there so that when you remove one you think it's clear to proceed but really isn't.
We won't talk about why I ask this. 8-)
treebound is offline
Reply
Old 08-19-09 | 01:54 PM
Panthers007's Avatar
Great State of Varmint
The "Case of the Hiding-Washer" is noted on Octalink bottom-brackets. Old square-tapers are more straight-forward. Make sure you have the correct puller. This, and a large wrench like a 12-inch adjustable, will work on both types:
https://www.parktool.com/products/det...=26&item=CWP-7
Panthers007 is offline
Reply
Old 08-19-09 | 02:10 PM
Noah Scape's Avatar
can't member
20 Anniversary
What kind of "puller" are you using?
Noah Scape is offline
Reply
Old 08-19-09 | 03:32 PM
NYC_zx10's Avatar
I Need Intervention
The incorrect one.
$10 bucks at my LBS to remove the crank and gut the BB.
NYC_zx10 is offline
Reply
Old 08-19-09 | 03:43 PM
I'll bet you used a wheel puller, used for pulleys, etc.
I used to use a wooden wedge once in a while, and still do, once in a while.
RobbieTunes is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
