Do you use pedal washers with your Sugino cranks?
Old 08-19-09, 07:50 AM
Yo!
Yo!'s Avatar
Bikes: Panasonic NJS Keirin x2, Level Professional, Bianchi CUSS, GT Pulse
I wonder about this; all of my "newer" style cranksets (external bb race face, truvativ, etc) come with pedal washers. However, my Sugino 75's did not.
I removed my MKS pedals last night to put some toshis on, and I noticed how marred the aluminum is around the pedal threading on the crank arm. Are you supposed to be using pedal washers with the Sugino cranks or what?
Yo! is offline
Old 08-19-09, 08:31 AM
adriano's Avatar
Bikes: https://velospace.org/node/18951
since appearance is the strong suit of the 75s, yes, you are.
α
adriano is offline
Old 08-19-09, 08:53 AM
Yo!
Yo!'s Avatar
Hey Adriano, what cranks are you running
Yo! is offline
Old 08-19-09, 09:08 AM
Beausage is Beautiful
Fugazi Dave's Avatar
Bikes: Nabiis Alchemy
Quoted: 20 Post(s)
Liked 13 Times in 8 Posts
Outside of carbon cranks, why the **** do you need washers?
Fugazi Dave is offline
Old 08-19-09, 09:17 AM
Yo!
Yo!'s Avatar
The wrench flats on cheap MKS pedals like the Sylvan and Stream create an offset gouge in the crank arm; models like the RX-1 have nicer spindles with a fully circular seating surface beyond the wrench flats, eliminating the need for pedal washers. Installing/removing the cheaper MKS pedals a few times creates an uneven seating surface at the spindle and crankarm.
I'm wondering if there's people who have noticed this issue after a few years of use and said to themselves, "Hell, I wish I'd have used some pedal washers".
I mean, the question really isn't that complicated.
Yo! is offline
Old 08-19-09, 09:22 AM
Bikes: Serotta Colorado III Track (Renyolds Ouzo Pro Aero Fork, Dura-Ace to Mavic CXP-14 wheels, Sugino crank, Thomson and 3T the rest), Steelman Cyclocross (Campy Record 10, Deda Newton & Thomson stuff)
Wanting to keep your cranks looking nice is perfectly reasonable, they're expensive and maintaining the threads and area around it will help re-sale value if you ever sell them in the future.
This is a case where there's no negative to using the washers, so why not? I haven't noticed any long term harm on my aluminum cranks, but there is some marring.
You can get a set here: https://www.velo-orange.com/pedalwashers.html
Or, probably from your LBS.
rudetay is offline
Old 08-19-09, 09:29 AM
adriano's Avatar
i run and rock suntour cyclones without washers.
α
adriano is offline
Old 08-19-09, 09:33 AM
Yo!
Yo!'s Avatar
Yea, you're right Rudetay.
Amidst all the flaming I seemed to have answered my own question.
This forum is the probably the best resource on the internet for quick, straightforward answers, pbft.
Yo! is offline
Old 08-19-09, 09:36 AM
Quoted: 20 Post(s)
How will a washer maintain the threads?
Also, I don't buy **** with the intent to sell it again. When I buy something I intend to ride until it's ground into the pavement.
I see no point in using washers on Al cranks. Had several second-hand cranks and none were ever used with washers and none ever saw ill-effects either.
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
