Tange Tubed Raleigh Criteium Frameset
Oddjob Cassanova
Bikes: 2005 Specialized Sirrus Hybrid, Unpedigreed steel frame fixie conversion (Force Disorder Pump), Pugeot UO9 fixed conversion (Red Menace). Lots of parts scattered about garage.
Howdy all,
Looking for any info at all on a Raleigh Criterium, All I can tell you is its Tange tubed with Suntour dropouts. By what was left on it, it was Shimano equipped. Raleigh was stamped into the upper ends of the seat stays and there are stylized R's on the fork crown shoulders. The paint scheme was violent pink & silver/grey.
I can find no account of this model (I'm guessing its a US model, manufactured in Japan) and I'm wondering if its rare, either because it was crap or something special.
Any info would be appreciated.
Thanks
Thanks
Bianchi Goddess
Quoted: 2925 Post(s)
Liked 2,921 Times
well let me be the first to "where are the pics man???" LOL assuming it is close to original paint maybe someone can tell the year. what kind of shimano did you take off?
Sugar "Kane" Kowalczyk
Oddjob Cassanova
Geez...ask the world. Pics coming shortly. Not sure what Shimano group was used...it had indexed/friction DT shifters. And it had Sugino dbl crank. And a fluted seatpost that was electrolytically welded in and needed to be destroyed to be removed (damn), also of Japanese origin.
Oddjob Cassanova
All right. You want pictures?
Bianchi Goddess
Liked 2,921 Times
WOW that is nice. a bit dusty in the corners but nice. the Raliegh experts will correct me but I think mid/late eighties. I am sure you know the Criterium frames have just a bit steeper angles and higher BB owing to the fact that are designed for criterium racing. this do you remeber what shimano you took off? I think maybe midlevel of their racing lineup. but I am no Raleigh expert
Oddjob Cassanova
Thanks all.
I've been liking the Raleigh approach to large frame sizes (taller BB to TT but not as long along the TT as some taller bikes, especially Peugeots). I have a Super GP fixed conversion (with YST pressure fit BB to replace the trashed Nottingham bits and threading) and the shorter cocpit feels right despite my size (6'3").
The Criterium feels even snugger. I probably shouldn't tell you its 90% destined for fix-ing.
Я люблю суп
That looks alot like the Raleigh USA models in the mid 80's. Does the serial number start with N or M. Can you post the serial number? Can you also post pictures of the head tube lugs?
Tange 2 is good stuff, so I don't think it is a low end model. I am guessing it is probably a Canadian model.
Oddjob Cassanova
Serial # for this Raleigh Criterium is N6A6798 .
On the underside of the BB shell, between the brazed on shifter cable guides.
www.theheadbadge.com
Quoted: 2420 Post(s)
Liked 4,381 Times
Oddjob Cassanova
The serial # on this frame seems to fit the convention used by Centurion...who the heck made this thing?
Paste Taster
Bikes: , Jury Bike, Moto Outcast 29, Spicer standard track frame and spicer custom steel sprint frame.
raleigh was having bikes made in japan by manufacturers like centurion and nishiki
it makes logical sense that this could have been built int he centurion plant for raleigh in the 80's
I am the owner of an 80's japanese bianchi alfana there is very little info about this as bianchi has tried to erase this bit of history
Quoted: 4722 Post(s)
Liked 3,036 Times
Probably a lot more info on that Alfana than you think.
Paste Taster
Really could you post a link I have been trying to find info it was a free frame and that's it
Oddjob Cassanova
Wha?
Liked 3,036 Times
You need to post some pics and specifics such as tubeset and serial number. However, I think you'll find it an early 1990s, lower mid-range model. The ones I've seen have been 105SC equipped.
Bianchi Goddess
Liked 2,921 Times
OH an '85? well I was very close eh? not bad. Retem Alfanas I believe started in 1990 what color was yours? Celeste or blue/white/silver? (90) or black? green/white? (those are '91 colors) it likely has a Superset frame set made with Tange Prestige tubing and came with Shimano 105 7spd dt. very nice bikes the '91 retailed around $800
Oddjob Cassanova
Begging the indulgence of anyone knowing the specs of their mid-80's Tange 2 tubed Centurions. I am looking to follow a hunch that my bike may be re-badged Centurion model;
I've taken some of the vitals of my apparent '86 Canadian market Raleigh Criterium and was wondering if they bear any resemblance to any 85-86 Centurion models.
(bear in mind I'm not frame builder but having perused specs before, I'll try to use common conventions and tell you whats being measured and from where to where.)
Raleigh Criterium, SN N6A6798
Seat tube (centre of TT to centre of BB) - 62cm
Top tube (centre of ST to centre of HT) - 57cm
Head tube (total length) - 20.8cm
Head tube (centre of TT to centre of DT) - 16cm
Down tube (centre of HT to centre of BB) - 62cm
Chain stay (centre of BB to actual end before drop-out) - 38.5cm
Seat stay (total length of stay) - 54.5
Geometry is based on the assumption that TT would be parallel to the ground when bike is shod. ST angle & HT angle were measured against TT with a particularly crude protractor.
ST angle - 72 degrees
HT angle - 107 degrees (this, I'm figuring would translate to the more recognizable 73 degrees in relation the ground)
This is in no way life or death. I've already bought the bike in question and its being built up to join my stable. I'm just curious about its lineage.
Thanks,
Dave G.
Thanks,
Dave G.
Liked 3,036 Times
It is not a rebadged Centurion though the frame was manufactured by the same company that manufactured Centurion frames during this period.
Oddjob Cassanova
Perhaps not re-badged, but at least having the same roots, specs etc. I've got enough to go on to tell me what it ain't, but little (oh, besides, I suppose the labeling & such) to tell me what it is. If it was a department store bike, I wouldn't be the least bit curious.
Liked 3,036 Times
Liked 4,381 Times
Oddjob Cassanova
Value, as in a dollar figure? Not at all. I most likely paid too much for it to begin with, so I'm not selling it because I'll never see what I paid. I bought it because it fit me and it will be used not too gently until it fails.
Its a beautiful bike in fit and execution despite not having the cachet of a true vintage gem, like say a Herse or a Schwinn Paramount.
I'm just curious, given that even the most modest bikes in my fleet have heritage. I've even seen more than one of the models I possess (while out on my blue/white Raleigh Record fixed gear, I can meet at least two other identical bikes in person). Throw in the internets, and you can find many such examples.
But I cannot find one other bike like this one. All accounts, catalog scans, specs, seem to end at '85.
Hey, wait. Maybe I'll sell it for a million dollars.
Paste Taster
Liked 3,036 Times
...I'm just curious, given that even the most modest bikes in my fleet have heritage. I've even seen more than one of the models I possess (while out on my blue/white Raleigh Record fixed gear, I can meet at least two other identical bikes in person). Throw in the internets, and you can find many such examples.
Evidence of your model does exist. I have two catalogs including it, though not your particular model year. So it was produced, for at least three years. Just not in large quantities, and only in Canada, eh.
