Scwinn World Sport mid 80's how to measure bottom bracket?
I am purchasing this crank to convert my schwinn world sport
https://cgi.ebay.com/EIGHTHINCH-FIXED...d=p3286.c0.m14
It requires a 103mm square taper, how can i measure my square taper to know that it will fit?
Insane Bicycle Mechanic
Quoted: 805 Post(s)
Liked 706 Times
Jeff Wills
Jeff Wills
will this bracket work
https://www.universalcycles.com/shopp...s.php?id=16123
will this bracket work, thank you for the help by the way how can i measure my tube to find out if you dont know off hand i already removed the old spindle this bracket looks like it may fit
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,924 Times
Hi ewingmaster. yes, as Jeff stated.that BB will work. I was looking at that 1/8 crank. you know you need a new chain right? the 'pitch of the teeth is not compatible with your "10spd" 3/32 chain
did you get you cog or single speed freewheel yet?
Sugar "Kane" Kowalczyk
yes, thank for your reply,the whole reason i am converting this bike is becuase i scored a track wheel set for $100 its a flip flop hub with 16 tooth cogs on both sides, i found a chain on the crank dealers website to fit it
Quoted: 805 Post(s)
Liked 706 Times
You don't have to measure anything. The bottom bracket shell on a World Sport is English thread- that's all you need to know.
Jeff Wills
Jeff Wills
Bianchi Goddess
Liked 2,924 Times
Ok
hey by the way how do i install something like that bracket does it thread though the right side down onto the left side? Do i need any special tools or should i take it to a local bike shop after i paint the frame and ask for them to install it for me?
