cyclocomputers & indoor trainers
Smooth like Butt'r
Bikes: 03 Bianchi Veloce in celeste
does anyone use a cyclocomputer when using their trainer? are there computers specifically for use with the rear wheel? wireless or wired?
Ride.
I drink your MILKSHAKE
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
Smooth like Butt'r
Originally Posted by drroebuck
My Astrale 8 uses the rear wheel. Cheap, too.
Bikes: '02 Trek 7200, '04Trek 5000
The Astrale8 is a wired computer that comes standard with a rear wheel mounted speed sensor and a cadence sensor. I've had mine for a week and it works excellent. I ride on a couple marked paths and its accuracy right on the money. The going price at the LBS, Dicks Galyans,etc near me is $39.95. Can be had cheaper mailorder through Performance, etc when on sale. Check out Cat eyes website.
https://www.cateye.com/en/products/vi...d=6&subCatId=0
str8shooter
str8shooter
Ride.
str8shooter
str8shooter
Guest
Posts: n/a
Quoted: Post(s)
Most people find that miles on the trainer are easier than road miles, so you might want to recalibrate the computer to make it more realistic. I used my 60% of maximum heart rate to figure it out.
In other words, when I was on the trainer with my heart rate at 60%, the computer, which was calibrated "normally", said I was doing about 25 mph (i can't do that). So, I had to calibrate the computer to tell me I was doing ~20 mph at the same heart rate.
Location: Latitude 42○13'44" Longitude 71○41'42" Elevation 223 ft.
Bikes: 2006 Merlin CR Works w/DA 10
I have the Polar 520i ... sensor on the rear wheel so I can use it on my trainer. Looks better there too. Nice thing about the Polar is that it displays HR also.
Smooth like Butt'r
It's working great. Love the display and all the info you can look at at one time.
I have the sensor on the rear chain stay (I think that's what it's called). In order to mount it there, you need to swap pins inside the sensor (my buddy did it for me - I can get more specific instructions if you want). The instructions don't tell you any of this - not sure why.
I did install the cadence sensor on the rear chain stay and crank arm also - and even though it's closer to the computer, the data seems to drop in and out. Not sure why - might just be a bad battery.
If you are using rollers, a front wheel mounted sensor works just fine. Where's the adventure in a fixed trainer anyway? If you can't fall, it's not really biking, right?
