Can BB7's be easily upgraded to larger rotors?
Old 08-22-09 | 06:17 PM
Guest
20 Anniversary
bfuser5893539 is offline
Reply
Old 08-22-09 | 06:29 PM
Luke52's Avatar
٩๏̯͡๏)۶
Bikes: 2010 Giant Filter 1. 07/08 Apollo Independent.
Fairly easy.
Buy some 203mm caliper mounts, buy 203mm rotors, install.
I don't think there's an upgrade kit, but I may be mistaken.
Also, what fork are you running? You may want to check the maximum recommended rotor size. Some forks can only take a maximum of a 7" rotor.
Luke52 is offline
Reply
Old 08-22-09 | 07:18 PM
Mr IGH's Avatar
afraid of whales
If you look on ebay you'll see folks dumping Avid roundagons for cheap, otherwise if you want something cool, here's your chance. ebay sellers also have the 203 brackets that will allow you to use your existing calipers. No size limit on your Suly rigid fork, some suspension forks have limits, esp the lower end ones.
Mr IGH is offline
Reply
Old 08-22-09 | 07:43 PM
Svr's Avatar
Svr
Bikes: Plenty
Originally Posted by CrimsonEclipse
Surly Rigid fork.
I didn't know there was limitations.
Make sure your quick release wheels are installed tightly and checked before every ride. Many of the suspension fork makers have revised the max rotor size on their 9mm QR forks. The increased leverage the brake can exert on larger rotors can also pull the front wheel out of the dropouts.
Svr is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
