Anyone on testosterone replacement?
I just got a physical and my blood test showed a low level of testosterone. My doctor recommended trying a testosterone replacement gel call Testim.
Anyone have any imput on testosterone replacement?
How big a concern are increased prostate problems when you go to testosterone replacement?
Time for a change.
Liked 5 Times
Makes you able to run the 800 metres faster than most others.
Don't think the Prostate will be affected- unless you already have a problem with it.
Spike Milligan
Spike Milligan
Bikes: Rawlings Drakkar, Specialized Roubaix, Pivot, Challenge Trike, Tandem
There is considerable concern about prostate cancer risks rising when testosterone is added.
Wonder whether there are any specifics about the degree of risk, etc
Climbing Above It All
The risks do not appear to be high. Let us know how it goes.
Go for it and find a 20 year old.
Unless you display symptoms associated with low testosterone, I wouldn't bother treating it. In my case, I was fatigued and was putting weight on around the belly. I went on a topical treatment and feel much better in all regards. The 20 year old suggestion would cause more problems and resolve none for me!
Bikes: 1997 Specialized M2Pro
This
https://www.thisamericanlife.org/Radi...px?episode=220
is a very interesting radio program about testosterone.
NYC
Quoted: 1169 Post(s)
Liked 107 Times
Or is that concern about adding testosterone up to normal levels?
Are said normal levels age adjsuted?
Saying "there is considerable concern about" something without saying what the specific concerns are (ok prostate cancer was implied), and the specific circumstances when the concerns apply... well, you get the idea.
chasing down blood sugars
Bikes: too numerous to count
Low testosterone reduces prostate problems. that's why surgical or chemical castration is sometimes used for advanced prostate cancer. Raising testosterone to average-for-age increases prostate problems to average-for-age. The anti-aging idea of raising testosterone level for a 60 yr old guy to that of a twenty year old probably isn't a good idea because the prostate gland is still 60 years old. if the friendly neighborhood urologist has already cut/lasered/cryo'd/microwaved it to the size it was as a youngster then maybe the youthful testo level might not be so bad.
If your testosterone is low-for-age you need additional testing to find out why it's low. your doctor can order blood tests for FSH, prolactin and ferritin. if your FSH is not elevated then you should get an MRI or CAT scan of the head with attention to the pituitary gland.
