Keeping low pressure in shocks- OK?
Bikes: Marin Pt. Reyes, Gary Fisher HiFi Pro, Easy Racers Gold Rush recumbent, Cannondale F600
I've recently graduated from my old Jeckyl to a Gary Fisher Hifi Pro, and am absolutely loving it- what a difference it is to have an up to date bike that I can dial in to almost any kind of ride! Have a question, though- I'm only 105 lbs. and am running the shocks at pretty low pressure (50-70 lbs. in the rear, for example) to get the proper sag and fork rebound. Should I pump them up in between rides, or will they hold up long term just fine with pressure set that low?
Thanks.
Thanks.
lungbuster
Bikes: Trek 5000 Road, SSFG Road, Kona FS MTN, Frankenbike
Check the pressure every few weeks. Shocks should not lose pressure that quickly.
^^Thanks. Yeah, I check all pressures when I've been off my mountain bike for a few weeks (which is a sign my life isn't going right!). So far they're holding pressure just fine. My main concern is with the longevity of the shocks- if the internal seals will go bad if there's not enough pressure against them for long periods.
