High End Tire Pumps
Bikes: Salsa Beargrease XX1, Trek Eqnuinox 9.9 SSL, Trek Madone 6.9 ,Trek District Carbon, Trek Boone7, Trek Fuel EX9.0,Trek Fuel 9.5, Trek Rumblefish Pro, Trek Remedy 9.9, Trek Equinox7, Trek District Belt
Quoted: 578 Post(s)
Liked 82 Times
High End Tire Pumps
Looking to purchase another floor standing air pump and currious what else is out there besides the Top End "JoeBlow" Pump..? Any suggestions..
Cheers, Jerry
Cheers, Jerry
Trek Fuel EX9.0 Trek Fuel EX9.5 Trek Equinox 9.9SSL TTX Trek Madone 6.9 Pro Red Project One, Trek Boone 7, Trek Rumblefish Pro, Trek Remedy 9.9, Trek Carbon District
Gear Hub fan
Bikes: Civia Hyland Rohloff, Swobo Dixon, Colnago, Univega
The Lezyne CNC Floor Drive. I have a cheaper model, the Classic, which is fine so far.
I also have the JoeBlow Ace dual tube pump which has worked fine so far and moves more air per stroke in high volume mode than the Lezyne.
Silca and Zefal also make some good pumps at least by reputation.
Gear Hubs Owned: Rohloff disc brake, SRAM iM9 disc brake, SRAM P5 freewheel, Sachs Torpedo 3 speed freewheel, NuVinci CVT, Shimano Alfine SG S-501, Sturmey Archer S5-2 Alloy. Other: 83 Colnago Super Record, Univega Via De Oro
Visit and join the Yahoo Geared Hub Bikes group for support and links.
https://groups.yahoo.com/group/Geared_hub_bikes/
I have this one and have had good luck with it so far..
https://www.parktool.com/products/det...7&item=PFP%2D4
Quoted: 578 Post(s)
Liked 82 Times
JoeBlow Ace
Yes I also have a JoeBlow Ace, but always looking for something different then what I have..!
Jerry
Jerry
I've never understood what makes a pump high-end versus low-end. What difference could there possibly be besides "pumps enough air into your tires" versus "can't pump enough air for high-pressure tires?" Durability maybe? Or weight, for frame pumps?
Quoted: 578 Post(s)
Liked 82 Times
Jerry
I bought a SKS pump a few years back and it's quite different from the $10 pumps I see at Wally World. Although it is made of metal like the less expensive pumps, the SKS feels more stout in comparison. The base on the SKS was a heavy chunk of cast metal with integrated air gauge while the less expensive pump used some stamped steel. Every part of the pump is modular and can be replaced; for example the hose and nozzle assembly is threaded on to the base of the pump where the $10 pump has the hose crimped on. SKS also provides lifetime warranty on their product.
A thinner pump may be easier to use at high pressures, but if you are trying to fill a high volume mountain bike tire it will take more strokes than a wider pump.
Lance Hater
Quoted: 7 Post(s)
I've got a Silca Pista that will last me a lifetime and then some.
Great State of Varmint
Liked 15 Times
This is an SKS Renkompressor 75th anniversary model (1932 - 2007) pump from Germany. It came with a bell-shaped chuck that really should be used with two people to operate it. I removed this and added the Hirame chuck. This pump delivers a very high-volume of air very quickly. This would explain it's being the pump of choice for European pit-crews on bicycle-racing circuits. The gauge is in Bars and goes to 17 - which is 246.5 PSI. This has a wooden handle with an actual leather grip.
Bikes: 2009 Caad9-5
+1 on the SKS Rennkompressor (might as well get the 75th anniversary).
Also, runner up for me was the Lezyne CNC track pump:
Bikes: See Signature...
Quoted: 9 Post(s)
I have a wrenchworks (I think?) high volume/high pressure pump. Easily pumps to 120psi (limit on gauge). I think I paid $30 for it 3 years ago. I would buy this model again, works awesome for a lower end pump.
I would surely go for all metal and o-rings if it was something to be used in high capacity. Something that the seals are replaceable!
Older than dirt
Bikes: Too darn many.. latest count is 11
The Specialized Air Force pumps are very nice also. I have a Joe Blow, but there are other nice pumps out there, many of which have already been listed.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Bikes: 2020 Veego 750, 2011 Specialized Roubaix Elite, 08 Trek 7200, Very Old Schwinn Cruiser
Quoted: 5 Post(s)
I have the Specialized floor pump. My son has the Joe Blow. We both like the Specialized better because the base is a triangle and it does not wobble around when you use it.
Other than that it pumps up the tire ....
https://www.specialized.com/us/en/bc/...sFloor&eid=384
Just a Cyclist
Bikes: 08 Trek Madone 5.5, 07 Lemond Versailles-Carbon, 06 Lemond Croix de fer-True Temper, 95 Bianchi Eros-Chromoly
Believe me, like anything else, you get what you pay for. I bought a very inexpensive air pump a few years ago and it literally popped and stopped working after just a couple uses.
"Per Ardua ad Surly"
Bikes: Bianchi Specialissima, Mongoose Hilltopper ATB, Surly Cross-Check, Norco City Glide
I have a Mt Zefal Husky floor pump for over a decade and it has served me well. It goes for around US$80 or so.
