Split Crown Race
Split Crown Race
Hey all, I picked up a used frame/fork recently, and noticed that the crown race was split. It looks really clean, and if I didn't know anything I'd think it was supposed to be there, but since I know just a smidge more than nothing I thought it would be best to ask. It's an FSA headset on a Scott CR1 Pro. Thanks for the help in advance.
Brian
Brian
Quoted: 2026 Post(s)
Liked 1,096 Times
Normal. FSA supplies split crown races on several of their cartridge bearing headset models since they can be installed with no tools.
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
+1
HR ain't pullin' your leg
72 Frejus (for sale), Holdsworth Record (for sale), special CNC & Gitane Interclub / 74 Italvega NR (for sale) / c80 French / 82 Raleigh Intl MkII f&f (for sale)/ 83 Trek 620 (for sale)/ 84 Bruce Gordon Chinook (for sale)/ 85 Ron Cooper / 87 Centurion IM MV (for sale) / 03 Casati Dardo / 08 BF IRO / 09 Dogma FPX / 09 Giant TCX0 / 10 Vassago Fisticuff
Steel Member
Bikes: N + 1
Quoted: 7 Post(s)
sorry to dredge up an old thread here, but I found the same thing on a circa 1987 Shimano 105 crown race. I've never seen one split like that (or noticed) before, but I haven't closely examined 100s of headsets either. I'm having trouble getting the headset (1" threaded steerer...again, circa 1987) adjusted with no fore/aft play, but the correct turning resistance...I figured it was the split in the crown race or worn out bearings (or both). I might pick up a handful of 5/32" loose bearings if a split in the race may be a factory thing. It looks very clean/machined...so if it's a stress crack, it's a darned clean one! (I should have taken a picture, sorry)
Quoted: 1572 Post(s)
Liked 643 Times
Steel Member
Bikes: N + 1
Quoted: 7 Post(s)
you're talking about measuring the head tube itself with the headset removed, correct?
I'm doubting that because it's not been loose. One evening on a cooler (ie, 50s/60s F) ride, it developed a bit of a "notch" in the centered position. I figured the bearings were gummed up and colder than usual so I took it apart yesterday, cleaned everything & re-packed it. Since then, it's seemed like there's no sweet spot of adjustment with no fore/aft but still with free rotation. Prior to that, it rotated freely except that it seemed to want to stop on the centered position, but had no fore/aft play at all.
headtube.
The "notch" is a classic symptom that the bearing races are worn in spots (specifically the spots that the bearings sit in with the wheel straight ahead.) Often happens if the headset is run too tight.
Some people report alleviating the problem by replacing bearing retainers with loose balls, or rotating the cups by 90 degrees in the frame; these might help but are temporary solutions IMO.
Steel Member
Bikes: N + 1
Quoted: 7 Post(s)
that makes sense. I picked up some more 5/32" bearings this afternoon & I'll try them. I had something similar in a very well-worn MTB I rejuvenated a few months ago...but it was generally notchy more than centered on any particular point. On that bike replaced that one with loose balls top & bottom (more to see if it would make a difference & give myself a real stark before/after comparison)...and, barring another rode-hard-put-up-wet 20 years that bike had between 1987-2009, I'd fetch a guess it's good for another 20 years as a tank of an urban assault bike...in other words, it's veeeeeerrrrrrryyyyy smooth. So, that's a long way of saying maybe I could expect the same result here?
Also...so, a split crown race may be a factory thing for this headset?
(OK, promise not to belabor it any longer...if the new bearings to smooth it up, I'll pick up a new headset + the tools I need to change it properly)
headtube.
I don't know what the deal is with the split crown race. If it's not a cartridge headset and the bearings are running directly on the crown race it doesn't sound right. Pic?
Steel Member
Bikes: N + 1
Quoted: 7 Post(s)
OK...guess I lied...still adding to the thread....Here's what it looks like. Using a some jewelers lenses, I could see some definite wear on the race, but it still looks like a nice clean crack. Guess my only question - more academic really - is whether it could have been made this way. Thinking about it, I can't imagine how it could be & be expected to work smoothly over time....
Liked 1,096 Times
That split isn't "factory", it's damage. Loose ball headsets do not come with split crown races, they are only provided on some cartridge bearing headsets.
Liked 1,096 Times
Quoted: 5774 Post(s)
Liked 2,571 Times
If the crown race is simply a seat for the inner race of a cartridge bearing, the split doesn't matter, and might even be designed in, working similarly to the split centering cone at the top of threadless headsets.
If the crown race is the actual inner bearing race as in most loose ball headsets the split is probably the result of being installed over an oversized crown. Crown races are through hardened, and have little capability for expansion when forced on. The crack will cause a slight click as the balls run over it, and will lead to degradation of the headset. It should be replaced, after properly sizing the crown race seat.
FB
Chain-L site
FB
Chain-L site
Steel Member
Bikes: N + 1
Quoted: 7 Post(s)
yes, the riding symptoms reflected that 'click', so that makes good sense. Interestingly - or not - this is the original headset for the bike...well, I guess unless someone between about 1987 & now replaced the headset with one from the same group (and period) but used a 26.4mm instead of 27" set....maybe? Whatever the case, it makes sense to me now so a replacement is about to be on its way & a proper press/installer fabricated. Thanks all.
Quoted: 1607 Post(s)
Liked 2,216 Times
I have a Campy SR head set with a split CR. I can't feel anything. I locate the split to the rear where the forces are minimal. Smooth as butter and a lot cheaper that buying a used headset for >$80 just for the CR!
I believe it happened upon installation in 1983. The difference between the ID and OD was creater than spec due to the paint overspray on the crown. I cleaned it up and reinstalled and still don't feel it.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
I was thinking that there's no urgency to replace those cracked crown races if you don't want to. It's not like a hub or bb in which the bearings are actually spinning .... they just sit there, moving slightly when you turn.
Steel Member
Bikes: N + 1
Quoted: 7 Post(s)
hmmm...hadn't really thought of that one. I could do that simply enough, but then again mine's not an >$80 part. If you *were* to select a location for the crack, would it be in the rear? a side? or just anywhere but right in the center?
Super Moderator
Liked 927 Times
I don't think it matters where the crack goes. Ideally you wouldn't want a ball bearing on when riding forward, but I don't think you can control that by the time everything's put together & adjusted.
Steel Member
Bikes: N + 1
Quoted: 7 Post(s)
I assume the front center is the point of highest stress on the race, considering the angle of the headtube (and loc of crack in my fork's case)...yes?
Quoted: 128 Post(s)
Liked 12 Times
In my case the split was lined up with the edge of the fork crown. I rotated the race so that the crack was over one side of the crown, where it would not experience shear force.
"c" is not a unit that measures tire width
