rear derailleur shifting on it's own
I am having trouble with my rear derailleur on my mtb. Whenever I go up hills and put a lot of force on the pedals it seems to just start shifting on it's own. I brought it into my LBS and they adjusted the cable and said it should be fine. However, on the next ride it did the same thing. Is this a problem with the cable tension or is there something wrong with the rear derailleur? Any help would be appreciated.
Thanks,
Ben
Thanks,
Ben
Bikes: Montague Folding/E-Bike, Kuwahara
Quoted: 31 Post(s)
Off the top of my head, my guess would be that the dérailleur and shifter need a bit of adjusting. Depending on how the parts are built, there will be barrel adjusters at both the derailleur and at the shifter. By tightening and loosening those, you pull the derailleur one way or the other so that it more precisely rides on the cogs.
I know that with some cheap indexed shifting systems, it is next to impossible to get it calibrated perfectly - either it will shift up well, or shift down well. Getting it to do both and stay put when in gear gets to be difficult.
Anyway, that's what my first guess would be. But see what others have to say as well.
Liked 7 Times
If a cable tension adjustment doesn't fix it then you may have a bent derailleur hanger. The shop should have checked for this.
Al
Al
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
also check the chain wear.
worn out chain can exaggerate minor issues with the cable or derailer.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
My bike's better than me!
Bikes: (2) Moots Vamoots, (1) Cannondale T2000 tourer, (1) Diamondback Response Comp mtb
Could be sticky cables and/or the guide under the bottom bracket, too.
Quoted: 1609 Post(s)
Liked 2,590 Times
Have you replaced the housing? Sometimes old housing allows enough friction to throw off adjustments.
Quoted: 31 Post(s)
