What is this bracket?
Bikes: 1974 Motobecane Grand Record, 1987 Miyata Pro, 1988 Bob Jackson Lady Mixte (wife's), others in the family
Quoted: 125 Post(s)
Liked 154 Times
I don't remember where I got this or what it was attached to, but I used it as shown to attach a rack to daughter's 80s Japanese mixte, which had no other way to do so. As you can see it's roughly U shaped, with the flat arms of the U turned 90 degrees. Any idea what this is or where I can find one?
Thanks,
Al
Thanks,
Al
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
I don't know what it was but I like what you used it for! it may have been some type of cable hanger that came off the seat binder.
Sugar "Kane" Kowalczyk
Cable hanger maybe?
It looks sort of like the bracket that was on a pulley I pulled off a girls frame that attatched to the seat binder and did the turnaround for the canti brakes (except obviously the one I took off had a pulley)
Quoted: 125 Post(s)
Liked 154 Times
Thanks, BG! I think you're right, it was attached to a seatpost bolt on one of the bikes that have passed through our family's hands. In fact I'm sure you're right. What it was doing originally I can't recall. One of the holes even had that 'keyway' from the binder bolt, and I had to drill it out to fit the screw from the rack's struts. Now I at least know where to look in the bins at the co-op.
Quoted: 125 Post(s)
Liked 154 Times
You posted while I was writing, Otto, and you are probably right, it was involved in hanging the straddle.
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
Lol. You could've just p-clamped it to the two seat stays. Extremely bad hardware used in that installation as well
1) Phillips head
2) No nylock nuts
3) No washers anywhere
1) Phillips head
2) No nylock nuts
Bianchi Goddess
Liked 2,923 Times
if you find an extra let me know
Quoted: 125 Post(s)
Liked 154 Times
If I find a couple (likely) one is yours, BG.
And thanks for your post, operator. I had a rack to get on the night before daughter's school, so not being a pro like (obviously) yourself I just made do. But I do appreciate the helpful comments.
