How often do you rotate your tires?
Pro Paper Plane Pilot
By that I meant swapping front to back and vice versa. Is there a guideline to how often? This is to even out the wear a bit. Or maybe it's not needed at all. Just place the front to rear when the rear's worn and buy a new tire for the front?
Quoted: 2952 Post(s)
Liked 3,106 Times
Cycle Dallas
Bikes: Dulcinea--2017 Kona Rove & a few others
Quoted: 197 Post(s)
Liked 10 Times
I use two different sized tires, so I don't rotate them. Here's what Sheldon Brown said about it:
https://www.sheldonbrown.com/tire-rotation.html
I follow Sheldon's method. When the rear tire wears out, I move the front one to the rear and add a new one up front. That way the newer and more trusted tire is always where it matters most.
GATC
Never rotate, don't see the point; rear tire takes it hardest, why put a weakened front tire on the rear where it will wear harder yet than it had been?
Never. I don't use the same tread front and back (though they are the same dimensions.) Rotating would mess with that. If a tire wear out, I replace it.
So what others and Sheldon is saying is wrong then?
Retro-Direct Fan
Never put the back on the front
I always intend to move the front to the back and get a new front. But after I notice the rear is too worn, there is a delay until I get around to it and or find a good deal on the relevant tire, so by that time I usually feel like the front is pretty bad, and replace both.
Put the best tire on the front. Just think about a tire failing and that wheel sliding out from under you; which wheel do you want it to be?
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
The point to Sheldon's method, of course, is to keep a good tire on the front and not throw out tires that are still usable. I suppose one could always donate the front tire to a community center when replacing both (assuming they'd want them).
Quoted: 8 Post(s)
I just moved the front one to the back and installed..... NO WAIT, I moved the R to the front and installed a new in the R.
In any case, I tend to find that on tires that I get a lot of flats on, it's always the R, thus when it's had 3 flats I assume the amount of tread is reduced enough to make it vulnerable to flats and then replace it.
In the past 6 years or so, I've been running Conti Grand Prix 4 Seasons and haven't had a flat in 2 years. Thus the front, for whatever reason, wore out first, so for no logical reason, I transferred the R to the F and put my last cheap Conti on the R, only as that's where I usually get a flat so why not have the newer tire there, Sheldons advice to the contrary. Or Not.
And I don't rotate.
Steve B.
And I don't rotate.
Steve B.
50/50 Road/eBike Commuter
Don't see any advantage that makes doing this worthwhile.
Bicycle Lifestyle
Bikes: Neil Pryde Diablo, VeloVie Vitesse400, Hunter29er, Surly Big Dummy
i rotate tyres often.
my ideal situation, is when both tyres are worn out at about the same time.
Bikes: trek 7.2, 7.3FX, 5200 OCLV
Why rotate?
I'll just use my worn out tires as spare. In fact, I hide my spares in several locations (trees/bushes, taped under mailbox, gas stations, etc) on my usual commute route to work. This saved me couple times on having huge gash on my tire. Beats walking all the way home than having a short walk to hidden spare location.
H23NC,
H23NC,
Quoted: 7348 Post(s)
Liked 2,465 Times
That's funny, h23nutcase.
That's not what he said. Again, you are twisting people's words.
Dude, you need to read more carefully. Sheldon (who is not the end all to be all, btw) states "The only time tire rotation is appropriate on a bicycle is when you are replacing the rear tire. If you feel like taking the trouble, and use the same type of tire front and rear, you should move the front tire to the rear wheel, and install the new tire in front."
He doesn't say that rotating tires is necessary, but that if you do, you should only move the front tire to the rear. From the article, it doesn't sound like Sheldon's a huge proponent of rotating tires (hence his statement "if you feel like taking the trouble").
I don't rotate my tires, nor have I ever felt the need.
Liked 2,465 Times
Right, it's not important, but there's no harm in doing it, either.
