Chain skip on 5th sprocket
Pro Paper Plane Pilot
I noticed today that there's some chain slippage when the gear is on the 5th (7 gears) sprocket. It happens every so often when I am hard on the pedal. It's a lousy feeling when I am climbing a hill too to have the pedal skip. It is also a sprocket that I use quite often in combination with my 2 largest chainrings.
Any help will be appreciated.
so can i just chain the cog or do I change the entire cassette? Dang.... The bike's only 3 yrs old and I've just started commuting with it this summer!
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
*Only* 3 yrs old? You do realize that's quite a long time in the bike maintenance world right? 7 gears... either it's a freewheel or it's a 7 speed casssette. Unless it's a particular high end one it'll most likely be cheaper to replace the entire unit - if that 5th cog is even available seperately. Can you please tell us what 7 speed cogset you have?
