Salsa La Cruz Anyone?
Bikes: I hate bikes!
Quoted: 431 Post(s)
Liked 710 Times
Just wondering if anyone here is using a Salsa La Cruz to commute and if so, what are your thoughts on the bike?
Bikes: 2009 Salsa La Cruz; 1997 Jamis Eclipse
I use it. I love it. I had the shop replace 105 with SRAM Rival. I am EXTREMELY happy with that choice. I opted for the compact crank with 50/34.
Gutter Bunny
Quoted: 16 Post(s)
I have one, lovely bike for commuting I do between 16km and 17km one way. If I had a more hilly commute I'd probably go for 3 chainrings up front, more touring style. The Disc brakes took a little getting used to with the dialing in, but are great. I love it. A great ride.
FNG
Bikes: Raleigh Special * Nishiki MTN Winter Commuter * Trek Soho 3 * Specialized Langster Seattle
that is a hot friggin' bike. i don't have one but would LOVE to get one.
Each Drop of Sweat Counts
Bikes: Trek FX2, Trek Verve 3, Dahon Launch D8, Dahon Jetstream XP, Dahon Speed P8, Dahon Speed TR, Dahon Speed TT
Liked 23 Times
Are there braze on's for a rear rack on the La Cruz. I can't tell from the web page or photos. That's about all that would hold me up from getting one.
John
John
There is one eyelet at the dropout. It's not a big challenge to mount your fender and rack in that eyelet. There is no upper braze-on or eyelet for rack mounting. I use an Axiom Streamliner Road DLX which mounts to the brake bridge. I know of at least three BikeForum users who do this with success, and I know of one for whom this did not work out (on a La Cruz). Here's a link to the rack:
https://www.axiomgear.com/products/ge...iner-road-dlx/
When I was considering how to mount the rack, I was torn between the brake bridge mount with this rack or using p-clamps to the seatstays. Since this rack can be had for cheap (a good deal cheaper than Axiom's SRP), I figured I'd give it a try. It hangs nicely behind my disc caliper, also keeping my panniers out of the way of my heels. I'm totally satisfied with the setup.
Let us know what you decide.
Non-Spandex Commuter
Bikes: Trek Soho S
Bikes: Trek 830 Mountain Track Drop bar conversion
You need to update your sig then!
Squeaky Wheel
I am thinking about building one up for my commute. Anyone have a feel for the differences between the La Cruz and the Casseroll (besides disc brakes)?
I considered this and rejected it. The outer diameter of the seatpost on the La Cruz is 30.0 mm, so not immediately compatible with any of the seatpost clamp solutions. The closest I came to the seatpost clamp solution was thinking of taking my 27.2 mm diameter seat post, shimming that to 28.4, and clamping a second seat tube clamp onto the seatpost just above the functional seat tube clamp. The second clamp would serve only to mount the rack onto the seatpost instead of the seat tube. I rejected that path in favor of mounting to the brake bridge, and I'm totally happy with the brake bridge mount so far.
Bikes: Trek Soho S
Rain Rider
Bikes: Breezer Beltway (commuter), Co-Motion Deschutes, Specialized Tarmac, Salsa La Cruz (rain bike), Co-Motion Tandem
Quoted: 20 Post(s)
I just bought a LaCruz. I'm using it mostly as a winter road bike (I have a Novara Randonee as my commuter bike). I've been very happy with the La Cruz but I only have 45 miles on it so far.
The best price I found was $1250 from Webcyclery
https://www.webcyclery.com/product.ph...&cat=77&page=1
Bikes: Waterford RST-22, Bob Jackson World Tour, Ritchey Breakaway Cross, Soma Saga, De Bernardi SL, Specialized Sequoia
Quoted: 196 Post(s)
Liked 6 Times
differences
The Casseroll has a steeper seat-tube angle but shorter top tube length, so it ends up fitting about the same as the La Cruz across the top.
La Cruz will handle larger tires (42 mm) since it's a cyclocross frame. Casseroll will handle 35 mm tires, 32 mm with fenders.
Head tube on the Casseroll is about 1 cm longer than La Cruz for a given size.
Chain stay is about 0.5 cm longer on the La Cruz.
The biggest difference between the frames, as noted, is the brakes. If they made the La Cruz with cantilever brakes, I would buy one but do not want disc brakes. Total overkill for my purposes and increases costs unnecessarily.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4335 Post(s)
Liked 2,977 Times
Quoted: 431 Post(s)
Liked 710 Times
