Want to upgrade Sora shifters...
Bikes: Specialized Allez and 2006 Specialized Transition Sworks
I own a 2005 Specialized Allez Triple with Sora shifters/brakes, Sora front derailleur, Tiagra RD, and 8sp Sora cassette but I want to upgrade the shifters to something better. What could I upgrade that to and what all would I have to replace (the less I can the better)? 105, Tiagra?
https://www.specialized.com/us/en/bc/...1&menuItemId=0
2005 Sora is 8 speed. To switch to Tiagra (9 speed) or 105 (10 speed), you'll need at least a new chain and cassette along with the shifters. Ideally, you'd also replace the front derailler. Shimano used to offer Ultegra-level 8 speed brifters styled like the newer shifters but they don't seem to be available any more.
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
Real Men Ride Ordinaries
Quoted: 17 Post(s)
what are you looking to gain from this upgrade? If your current brifters work fine, I'd just leave them be. Even if they're a bit slow on the upshift, there's a good chance it's an adjustment issue rather than the brifters themselves.
Bikes: See Signature...
Quoted: 9 Post(s)
nothing wrong with 9 speed at all. It is still the norm for mountain biking.
I had a 2006 Allez, and the sora brifters SUCK. its almost impossible to reach the thumb lever if your in the drops, and I guarantee that is why the OP wants to replace them!
Search ebay for some gently used Tiagra, 105 or higher 8 speed brifters, or make the upgrade to 9 speed, which you will still have to search for for road bike. 10 speed would be great, but all the components are $$$ you would be better off buying a whole new bike.
"I had a 2006 Allez, and the sora brifters SUCK. its almost impossible to reach the thumb lever if your in the drops, and I guarantee that is why the OP wants to replace them!"
Exactly... The shift ok... but the placement is what is awful about them
Guest
Posts: n/a
Quoted: Post(s)
I'm going to upgrade handle bars on my commuter bike from flat to road.
What I have:
- Scattante R-330 2006
- RD Sora 8 speed
- FD triple 8 speed
- "new" road handle bars + stem + 105 levers 10 speed.
The Shimano compatibility chart says 105 10 speed levers aren't compatible down.
https://bike.shimano.com/publish/cont...ty%20Chart.pdf
Q1: Why?
Q2: What to upgrade to make it compatible?
What I have:
- RD Sora 8 speed
- FD triple 8 speed
Q1: Why?
10 speed levers shift different spacing than 8 speed. Along with the bars, you'll need brifters, chain & cassette and should also replace FD, RD and chainrings if you want everything to be smooth.
I missed that you had a Tiagra RD. Sora FD / Tiagra RD should fine.
When I suggested upgrading derailers, it wasn't because of incompatibility. With all the other things you'd be upgrading, it would just make sense, in my opinion, to spend a bit more and get away from Sora derailers (especiaslly the RD).
Quoted: 140 Post(s)
Liked 162 Times
All the modern Shimano rear derailleurs (including mountain bike rear derailleurs) have the same cable pull ratio, meaning they all move the chain the same distance when the shifter pulls/releases a certain amount of cable. So modern Shimano rear derailleurs really don't have "speeds," although they may be marketed as such. The number of "speeds" is in the shifter and cassette.
The only exception to this is 8 speed and earlier Shimano Dura Ace, it had its own cable pull ratio.
Guest
Posts: n/a
Quoted: Post(s)
Do I understand right following?
The 10 speed shifters should be used with 10 speed cassette; and double shifters should be used with double chain rings. The derailers will work well with 8-9-10 speed shifters.
