Need Help with chain
Bikes: Bianchi SISS singles speed, Scandium Salsa Bandito, Kona Major Jake, Gary Fisher Big Sur, NashBar Aluc
I just bought a Schwinn IC Pro spinner bike (for winter training). It is a fixed gear and running 1/8" chain. However it seems to be making a clicking noise on every single tooth of the fly wheels chain ring. Ive tried loosening it and tightening it, No help. I read somewhere once that getting a machined sprocket vs a stamped sprocket can help cut down on unnecessary noise because they are more circular. Does anyone have any ideas. I tried lubing the chain, I decreased the factory chain lube and used a wax lube which just made it louder. Im SOL on ideas.
Yeah it appears to be relatively straight. Its just a click with every tooth that comes in contact.
Bikes: Panasonic NJS Keirin x2, Level Professional, Bianchi CUSS, GT Pulse
Are you sure it's not just the noise of the rollers contacting the ring?
Even when mine is packed up with grease and fresh from being cleaned, it'll make a very faint ting noise as the roller hits the chainring.
Are you a perfectionist? Fixed gear drive trains are some of the noisiest around.
