Fixed wheel is slipping forward on the drive side
No matter how tight i tighten my wheel, it keeps slipping forward on the drive side. I did a quick search and came up with nothing. This happens in as little as half a mile into a ride. The problem started out as going up steep hills the wheel would completely torque to one side and start rubbing against the frame. My bike mechanic just joked around and said you are a beast. This happened twice. Any help is appreciated.
Quoted: 5774 Post(s)
Liked 2,571 Times
There's a reason track hubs have traditionally been bolted on with 10mm fine threaded nuts. Holding power. The shallow ramp angle of a 10x1 thread ensures a compression force of nearly 30 times the torque, or almost double that of a 6mm thread. Combined with the higher maximum torque of 10mm hardware the system assures a solid mounting.
If there's a way to replace your axle set, I suggest you consider going to a traditional solid axle system. Otherwise look for a hardened steel serrated washer with sharp points which will bite into the dropout and hold with the lighter compression force of the hex cap screws.
FB
Chain-L site
FB
Chain-L site
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
what kind of skewer is that?
honestly, it doesn't seem strong enough to hold the wheel in place along hardened steel.
if you can use a QR with that wheel, try a shimano closed cam QR with it.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
I don't think it is a skewer. I think it is two allen bolts that thread into the axle.
Sugar "Kane" Kowalczyk
Yes it is two allen bolts threaded into the axel. Currently I do have serrated washers on the wheel, although it may be hard to see in the poor quality pictures. This is the wheel if it is any help.
https://www.amclassic.com/products/ro...s/420track.php
let me know if there is any other info or pictures needed. Thank you for the the help so far.
Quoted: 16 Post(s)
Traditional track nuts are better. Get better serrated washers or go old school and add Chain Tugs. Those allen bolts don't look like it's applying enough pressure on the entire surface of the washer, just the center. Wouldn't be surprised if the washer was concave in the middle. would have to add 2 flat washers of different diameters (same size, smaller washer, then allen bolt) to get more even pressure and gripping power if you stay with the allen bolts.
How hard would it be to switch to a traditional track nut?
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
cab horn
Quoted: 42 Post(s)
Liked 26 Times
From the picture it looks like a silver type washer that wouldn't be serrated. I hate to admit that you might actually need to install a chain tug on the driveside if nothing works.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Wow wtf, did you even look at the pictures? It shows a giant serrated washer on top of a bolt. The slick chromed/stainless dropout surface of the OP's bikes dropouts don't help in holding power - are the inside locknuts facing the dropout serrated? If they're not that's another thing you can try.
Real Men Ride Ordinaries
Quoted: 17 Post(s)
Ok, here's a thought. Reputable manufacturers, like Phil Woods and American Classic wouldn't make a product with such an obvious failing. There must be a way to get them to work.
Now think of this, how long is your average 15mm box wrench? A good 10 inches or so, at least.
Your average 6mm allen wrench? You lucky if you have 3 inches or so. You need more torque, and a bigger wrench.
Bikes: Cervelo Soloist Team
+1 on the chain tensioner. These are only $11 and come in pairs for both sides
https://www.jrbicycles.com/storefront...&productId=105
Next time buy a decent hub with a threaded axle for bolts. I can't imagine why that hub has a bolt on skewer.
Funny thing, I was looking at a motorcycle next to me at a traffic light today. Yamaha R1000 I think. Anyways, it has horizontal drops and a chain tensioner on the rear axle.... thought that was pretty cool.
What is the recommended torque spec for the bolts on that hub? What torque are you using? If you don't know, that's likely where your problem lies.
Sorry if this is too obvious but are you sure you have a short enough length of axle showing on the drive side? If the axle extends all the way to the outside edge of the drop it won't matter how much you torque down the nut.
