New B&M generator-powered rack light
Bike ≠ Car ≠ Ped.
While looking around for the 4DLite Plus for this thread, I saw this:
https://bumm.de/index-e.html?docu/323e.htm
They call it a Toplight Line, with a "LineTec" lens for its two LEDs. I think it's supposed to give better dispersion side-to-side but, more importantly, instead of appearing as a single point of light, it looks like a bar of light, which should help onlookers better estimate your distance and speed.
I like my Selectra ( https://bumm.de/index-e.html?docu/320e.htm ), but this new one looks pretty cool. I'll see if I can get a hold of one in a couple months or so.
Bikes: S5 VWD & SL-7 S works Red.
Quoted: 52 Post(s)
Why go with a generator? Wouldn't rechargeable batteries be simpler, lighter and provide less drag?
Scott
Bikes: Too Many
Drag is not very much even when using bottle type dynamos. After a few minutes of riding you forget the very slight drag imposed by the dynamo.
Infamous Member
Bikes: Surly Big Dummy, Fuji World, 80ish Bianchi
weight isn't much of an issue unless you are racing
drag on modern dyno-hubs isn't worth worrying over, unless you are racing
generator power is more Murphy-proof than battery power
Genetics have failed me
Darn it. Just after I purchased a XS plus for me and my wife a few weeks ago.
And yes, a hub generator is definitely the way to go for multi-day touring rides.
Gelato aficionado.
Gelato aficionado.
Quoted: 539 Post(s)
Liked 44 Times
Batteries are not required; no need to worry about recharging them, purchasing new batteries when your old ones are worn out, and it's better for the environment.
Bike ≠ Car ≠ Ped.
The weight issue is negligible, too. If you want to get wild about it, you can get a dynohub built with a carbon rim.
But, that's not relevant -- what's relevant is the weight of the lighting system. The weight of the dynohub (minus the weight of a regular front hub) and the weight of a typical battery pack seen on most worthwhile lights are basically the same, so, I'd say that the weight question is moot.
https://www.supernova-lights.com/en/dynamowheels.html
Yeah, that Toplight XS is what I had in mind to get (after browsing Peter White's and Harris Cyclery's pages), but the guy at the shop while I was in Germany last Christmas pulled a Selectra off the shelf and handed it straight to me. Three LEDs and a bigger reflector trumps one LED.
Quoted: 539 Post(s)
Liked 44 Times
Bike ≠ Car ≠ Ped.
Probably the most complicated part of a generator setup is the wiring installation. But, the time spent doing that -- maybe 15-20 minutes, not in a hurry at all -- more than compensates for the time I've spent switching out batteries and checking them... and sometimes re-recharging them because they've sat dormant long enough to lose charge while the dynohub bike gets ridden more often.
It doesn't make for good forum discussion, though, because it's literally set it and forget it -- I can come back in five years and say, "My lights still work and I haven't touched a battery." Boring.
Anyway... the new light looks pretty neat, doesn't it? There aren't many images out there, just some PR stuff from Eurobike.
https://www.eurobike-show.de/eb/press...e=detail&lg=en
https://www.pd-f.de/component/option,...lection_id=528
Oh, cool -- they're coming out with their own "Power Supply Unit":
https://bumm.de/index-e.html?docu/361e.htm
Quoted: 539 Post(s)
Liked 44 Times
I, personally, have more of a "wait and see" attitude about the tail light.
Yeah a generator is a good way to go, even if it's a sidewall dynamo. I've had both AXA and B&M; both are good. But it helps if you get tires with a sidewall tread strip (although it's not necessary with the B&M 'cause it can be fitted with a wire brush-type wheel). My tires are 1.5 Marathons, so a dynamo is the perfect solution for on-demand lighting. I've toured through many countries this way; tens-of-thousands of kilometers on both diamond frame and recumbent, which both have the same setup. I've always had the DToplight Plus with condenser and B&M headlight.
Battery lighting is impractical because I tour mostly at night, and charging would be a problem sometimes. Having battery-powered front-and-back strobes for auxiliary is good though. They last forever. Plus I can switch-on the front steady beam for extra light when needed.
Infamous Member
They put out plenty of output for 'normal' night riding. But of course more light never hurt anyone, so you can always supplement with battery powered lights. When I commute on my Superbe I also run a P7 and a PBSF, in addition to the dynamo powered B&M head/tail lights. Redundant systems are never a bad thing.
Bike ≠ Car ≠ Ped.
After seeing lights like these "in the wild", I figured that they were bright enough, whether they had an LED or a filament bulb.
