The world is really different down low...
Tonight I decided to do my 10km commute totally in the track drops. I regularly use them but only for sprints and flats. It really is painful on the back of the legs but I assume this is due to me not being used to holding that position for a long time. Surprising how much torque you can lay down in that position though. Do any of you drop people ride in the drops often? If so, i'm wondering how much seat to drop bar "drop" is usual or acceptable on a track setup bike?
Track cyclists are always in the drops, except maybe when warming up or goofing around. A GIS will give you a good idea of what properly set up track bars look like; a lot of street riders put theirs at a level that trackies might consider ridiculously low.
I can stay in the drops all day on my road bike but they are pretty high; the tops are just a couple cm below saddle height.
[Edit] Ninja edit fail
aka mattio
How much drop, drued? That depends on a person - on how long their various body parts are, their flexibility, and whatnot. Pro teams do a bunch of aerodynamic testing - the test various aerodynamic positions of a rider, and then they go out, set up a bike, and run a bunch of power tests to determine maximum aerodynamic advantage and maximum power output.
Some rules of thumb are, your elbows should be bent, you should consider riding longer, not lower, if you're trying to get into a decent race position, aim for a flat back, and don't be in a stiff-armed position.
Bikes: Fiori Fixie powder blue w/ granny bars
Quoted: 6495 Post(s)
Liked 29 Times
I ride drops always. I find myslef crouching over when holding the flat part of the bar, so why not just grab the drops
Bikes: Panasonic NJS Keirin x2, Level Professional, Bianchi CUSS, GT Pulse
I love drops, and I hang out in them all the time. I use the B125's.
I recently moved to RB-021's and I really like how I can put more weight over the front wheel and still have some drop.
Raving looney
Bikes: 70s Leader Precision w/Shimano 600 (road), IRO Rob Roy (Fixed)
manonthemoon
Bikes: Current custom builds: FG=KHS Flite 100 DH=Transition Blindside FR=Transition Bottlerocket
...or the abbreviation for General Mills' stock
Bikes: 2010 Specialized Allez Steel| IRO Mark V fixed gear
thinking about switching out my bullhorns for drops, but don't wanna dish out more money for a new brake lever...
n00b
Bikes: Mercier Kilo TT - Grapesoda
at brisk speed i love the drops but when theres heavy traffic i ride the tops bc the brake lever is way too far to reach when i need to oh-****-brake.
its about 11" from the center of the drop bar to the top of my seat. it seems like a deep drop but i just have long arms (5'6" height, 70" arm span) and i still have some room to bend my elbows.
some like the look of the the drop angle matching the angle of their quill stems. some like it higher. its all just fit preference. but track bikes usually have an aggressive position anyway for more aeroness
n00b
I have a set of the 021's on my old fixie. Great bars but the drops look so sexy on the panasonic. i guess im in a pretty aggressive position while in the drops but still have a bit of arm bend. it really is amazing how fast you can go while in the drops :-)
O
O
