going from 50/34 to 53/39 crank
Old 10-20-09 | 05:56 PM
Other than moving the front derailleur, do I need to lengthen the chain or anything else?
jtuba is offline
Reply
Old 10-20-09 | 06:00 PM
Very possibly the chain... Check the big/big combination and note whether the rear derailleur pulley has enough clearance.
dwr1961 is offline
Reply
Old 10-20-09 | 06:02 PM
c.miller64's Avatar
15 Anniversary
Bikes: Cannondale Six13 Pro, Cannondale Synapse, Felt IA10, BMC TimeMachine
I just did this in reverse swapping an Ultegra 53/39 for a 50/34. Adjusted the FD and took a couple of links out of the chain.
More than likely you'll have to add a couple.
c.miller64 is offline
Reply
Old 10-20-09 | 06:07 PM
JiveTurkey's Avatar
Low car diet
Bikes: 2006 Windsor Dover w/105, 2007 GT Avalanche w/XT, 1995 Trek 820 setup for touring, 201? Yeah single-speed folder, 199? Huffy tandem.
Possibly need to lengthen the chain. If the chain was previously sized to be as short as possible with the 50T ring, then it will be too short for 53T. See here: https://sheldonbrown.com/derailer-adjustment.html#chain
Before adding links, think about this:
1) Does the chain require a special connecting pin (Shimano) or quick-link? The design of newer chains allows the chains to be stronger, but removing and re-connecting the same pin can damage the outer plate, creating a significant weak spot.
2) How old is the chain? If it's stretched enough, it may be best to just replace the whole chain.
JiveTurkey is offline
Reply
Old 10-20-09 | 06:09 PM
JiveTurkey's Avatar
Low car diet
Also, going to a new crank may require a new bottom bracket if the crank/bottom bracket interface is different (square-taper vs. ISIS vs. External, etc.) or a different spindle length is required.
Reply
Old 10-20-09 | 07:31 PM
ejbarnes's Avatar
Determined Survivor
Bikes: Cervelo R3, Specialized Transition, Kona Paddy Wagon, Giant TCX. Lots of bikes in the Garage.
Don't bother changing the botom bracket or even the crank arms.
Chances are your 50/34 is a 110 not a 130mm.
I made the same move as you.
I just ordered a 52/38 set of chain rings.
The theory is that the change only cost about $150 and if I am planning on a big hard hilly Century the chain rings can go back to 50/34 in a couple of minutes.
My problem with the 50/34 was that I didn't like the big gear spread. If you are just looking for speed it is not rally going to gain you very much. Why not install a 23-11 or a 25-11 cog? or If you really believe that you have power to burn try a 21-11 cog.
Much easier to change sprockets than chain rings.
ejbarnes is offline
Reply
Old 10-20-09 | 07:36 PM
cab horn
20 Anniversary
Bikes: 1987 Bianchi Campione
You have to check the chain length in the big/big combo.
operator is offline
Reply
Old 10-20-09 | 07:41 PM
If the problem is the big ratio jump between the 50 and 34 another option would be replacing the 34 with a 36.
Al
Al1943 is offline
Reply
Old 10-21-09 | 12:25 PM
Thanks for all of the input. I'm in the process of acquiring parts so I can build up a second bike. I would put the 53/39 on my main bike and put the compact on a second bike. Some good CL deals on cranks now. I'll get some advice from the LBS as far as chains go too.
jtuba is offline
Reply
Old 10-21-09 | 01:11 PM
Measure the chain with a good steel ruler.
Al1943 is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
