Chain tension, can someone please explain this to me?
Old 10-20-09 | 07:37 PM
So I got my first fixed recently.
I can seem to get enough tension without a chain tensioner. Now I got one and Im afraid to over do it an rist breaking a chain mid ride (which I'm guessing would suck since I ride breakless.)
I searched around this forum and other places and cant seem to find a good concise explination of how much tension is just right and how to gauge tension properly. Anyone have a good explination or easy way to know when your chain is on correctly?
RooNYC is offline
Reply
Old 10-20-09 | 07:49 PM
acoustophile's Avatar
15 Anniversary
To quote Sheldon Brown:
"It should be tight as it can be without binding. If the chain is too loose, it can fall off, usually at the most inconvenient possible time."
https://sheldonbrown.com/singlespeed.html#tension
acoustophile is offline
Reply
Old 10-20-09 | 07:56 PM
feetpower's Avatar
n00b
Bikes: Mercier Kilo TT - Grapesoda
trick i learned from an lbs:
loosen the rear, pull it back all the way and tighten the nut just enough so that it holds its place, lightly "pinch" the top and bottom chain together between your index finger and thumb. this should scoot the rear wheel forward just barely to give more slack to the chain from the original tight position.
or just stick your hand between the rear wheel and seat tube and push it back and adjust the tension manually. ive done it this way but its always hit or miss and i have to do it a couple times to get the tension just right.
when its at the correct tension, the chain should have some up/down play of 1 cm. from far away your chain should look like it has a very very very slight droop in it.
feetpower is offline
Reply
I did read that on Sheldon Brown but Im still afraid I might be tightening too much even though the chain is not binding or slowing things down.
Thanks feetpower.
RooNYC is offline
Reply
Old 10-20-09 | 08:00 PM
zeBRAHz's Avatar
likes black bikes
Bikes: 2008 DK General Lee, Kilo TT
biggest problem with cycling right now. kids get 'fixed gears' because something on the internet told them it was cool. so they start riding in traffic with no experience and no knowledge and just up that hate for cyclists a little more.
zeBRAHz is offline
Reply
Old 10-20-09 | 08:15 PM
Easy buddy, Im 35 and have been riding bikes since I was a kid. I've always wanted to learn to ride a fixed gear bike and did so over the course of a few years with friends fixed gear bikes a flip flop hub and breaks on one of mine. I just removed the front break last week after "using it" for 3 month (by using I mean having it mounted to my fork since I never actually needed it to stop.)
RooNYC is offline
Reply
Old 10-20-09 | 08:16 PM
TejanoTrackie's Avatar
Veteran Racer
Titanium Club Membership
15 Anniversary
Bikes: 34 frames + 82 wheels
You have to adjust the chain at its tightest point. First set the wheel straight in the frame and pull it back until the chain starts to resist and lightly tighten the nuts. Rotate the crank about a 1/4 turn at a time and push up on the buttom run of the chain and feel/see how much it moves up. Repeat until you find the tightest point at which it deflects the least. Re-adjust the wheel at that point so the chain deflection at the bottom is between 1/4" and 1/2". Re-check to make sure it does not still have a very tight spot. The variation of chain tension at different points will depend on the quality (roundness) of your chainring and cog. BTW, this is how we do it at the track where we are constantly removing and installing the rear wheel to change gearing.
TejanoTrackie is offline
Reply
Old 10-20-09 | 08:17 PM
destikon's Avatar
FNG
Bikes: Raleigh Special * Nishiki MTN Winter Commuter * Trek Soho 3 * Specialized Langster Seattle
So I got my first fixed... /// I ride breakless.
eek
Originally Posted by powers2b
time's up
destikon is offline
Reply
Old 10-20-09 | 08:27 PM
Originally Posted by destikon
eek
I should have clarified that I rode my old roommate's fixed gear alot back in the early 90 and felt comfortable. I also had a moutnian bike with a flip flop hub back in 2001 and would frequently set it up fixed. I can stop very easily and comfortably (I live in the Washington Heights section of NYC with big hills and they are not problem stopping on.)
just because someone is buying their first car, doesnt mean they cant drive people.
RooNYC is offline
Reply
Old 10-20-09 | 08:31 PM
destikon's Avatar
FNG
^^ i got what your saying but seriously, slap a brake on whatever you ride.
time's up
destikon is offline
Reply
Surf Bum
Bikes: Lapierre Pulsium 500 FdJ, Ritchey breakaway cyclocross, vintage trek mtb.
Riding breakless must get very tiring. How do you sleep?
Personally I like to take a break now and then.
pacificaslim is offline
Reply
Old 10-20-09 | 08:34 PM
cab horn
20 Anniversary
Bikes: 1987 Bianchi Campione
Learn how to spell seriously. It's brake.
operator is offline
Reply
Old 10-20-09 | 08:35 PM
cab horn
20 Anniversary
Yeah, because obviously everyone obtaining their new fixed gear fashion accessory is up to snuff with their riding skills. Good job with the bad advice. Is it going to take a dead white girl for people to stop giving ********ly unsafe advice? Or what?
operator is offline
Reply
Old 10-20-09 | 08:44 PM
Doh, brake it is. And I missed where I was giving advice operator. Last time I checked, I was asking for advice on chain tension.
RooNYC is offline
Reply
Old 10-20-09 | 08:50 PM
Please don't ride on the road without brakes. We lost a state champion that way.
CycleBiker is offline
Reply
Old 10-20-09 | 08:52 PM
15 Anniversary
If the chains not binding and not too loose then yr set. As long as you didn't mess up anything on the chain itself when breaking it, there should be nothing to be paranoid about.
Reply
Old 10-20-09 | 08:56 PM
Thanks all for your tips.
I think I got the idea on chain tension and sorry I opened up the whole brakeless discussion by accident.
RooNYC is offline
Reply
Old 10-20-09 | 08:59 PM
dsh's Avatar
dsh
Oh, you know...
Bikes: '74 Schwinn Sports Tourer (Polo), S-Works E5 Team Festina (Chorus 11), Trek 2200 Bonded Carbon (Fixed), Trek 920 (7 speed IGH), Chesini Olimpiade SL (1x7)
Just pull it back with your hand until the chain stops you from going back any further, then tighten the drive-side bolt down. Make sure the wheel is straight on the frame while you tighten the non-drive side.
Don't lean in it or pull really hard or anything. The chain does not have to be that tight if you've got your chainline set up within a few mm. Dropping chains with a good chainline is hard to do.
dsh is offline
Reply
Old 10-20-09 | 09:16 PM
hairnet's Avatar
Fresh Garbage
Bikes: N+1
This is a fairly easy way. Just beware, this method also makes it easy to make the chain way too tight.
https://www.youtube.com/watch?v=kW3pTjm5ZMY
hairnet is offline
Reply
Old 10-20-09 | 09:36 PM
Great YouTube video, thank man!
RooNYC is offline
Reply
Old 10-20-09 | 10:02 PM
Veteran Racer
15 Anniversary
Ya think?
Reply
Old 10-20-09 | 10:22 PM
hairnet's Avatar
Fresh Garbage
Bikes: N+1
Originally Posted by TejanoTrackie
Ya think?
lol
but you can also get it without being overly tight. I just practiced a few times to get a feel for it before setting the chain and riding. It's easier than pulling back on the wheel.
hairnet is offline
Reply
Old 10-20-09 | 10:50 PM
Veteran Racer
15 Anniversary
lol
Oh, I'm sure you can. I was just amazed at how that tatted bike monkey could get that chain so tight that you could play it like a guitar and then say that it was the correct tension.
Reply
Old 10-21-09 | 03:39 AM
Azul the Cat's Avatar
*meow*
I like the tennis ball method. Works well for me all the time and super easy.
1. wedge tennis ball between frame and wheel
2. tighten axle nuts
3. **********
4. profit!!
Azul the Cat is offline
Reply
Old 10-21-09 | 07:06 AM
blasternot112's Avatar
Wrench - Racer - Fanatic
Bikes: 2007 Novara BigBuzz, 2001 Trek Y-1, 2007 Gary Fisher HiFi, 2006 Cannondale CAAD8, 1986 Peugeot Fixie Tourmalet PH10-LE, Kuwahara Road Tandem, Marinoni Corsa, Trek 810 Steel, 1998 Cannondale m300, Cannondale m600
Moral of the story: Don't rip those uncool brakes off until you learn how to mount a rear wheel to the frame properly, especially if your going to galavant around with only your chain as a "brake"
blasternot112 is offline
Reply
