jtek shiftmate install question..
Bikes: Surly CC, Raleigh Team Pro, Specialized Rockhopper with an xtracycle
I asked this in c&v and didnt get any responses so i figure i'd try here.
I just installed this and it seems like i may have installed it incorrectly. My cable housing enters the device and is secured via the hole, but the exit cable simply butts up against the supplied nipple and the nipple is inserted into the derailleur body. There are no grooves to hold the nipple in place against the shiftmate. It pretty much is pushed up against the surface of it shiftmate and is held together with the tension of the cable being fastened to the derailleur.
Am I missing something or is this supposed to be how it is put together??
Quoted: 1074 Post(s)
Liked 295 Times
Quoted: 2026 Post(s)
Liked 1,095 Times
You have it right. The cable exits the "pulley cage" directly into hole in the flat surface of the nipple which goes into the barrel adjuster on the derailleur. The nipple is just butted up against the cage and held only by the cable tension. It works fine.
