Questions
Generalfeldmarschall
Bikes: Red 1988 Peugeot Nice Road Bike.
Questions
I am new to serious biking and also to the forums. I have two questions that I was wondering about.
1. does the "speed" of the bike refer to the total number of gears available or does it refer to the amount of rings on the cassette?
2. I recently purchased a 1989 Peugeot that would be either a 6-speed or a 12-speed depending on the answer to the first question as it has two rings on the crank and 6 rings on the cassette. Would it be possible to outfit my bike with brifters?
I have senior moments...
Bikes: Many
It really doesn't matter what you call it, and you can add up chainrings and cogs if you want, or just the cogs...
Might want to read this article https://www.sheldonbrown.com/speeds.html regarding changing drivetrain on your pudgit.
Typically, the bike itself is advertised with the total number of gears. In other words, a mountain bike with 7 rings on the cassette and 3 rings on the crank is advertised as a 21-speed.
However, in terms of component groups, they'd refer to the number of rings on the cassette and the number of rings on the crank separately. For instance, my road bike is a SRAM 10-speed Double (10 on the cassette, 2 rings on the crank) and my mountain bike is a Shimano 7-speed triple.
Newer bikes to the available cogs on the rear cassette (8, 9, 10, 11 speed) but in actuality you would have 16, 18, 20, 22 available speeds (-2 if you don't cross chain) (or triple the rear if you run a triple front crank)
Yes you could outfit your bike with brifters, however you would have to change your entire drivetrain (cranks, chain, at least the rear hub and cassette) and you may or may not have to spread your frame depending on the spacing, typical to your year, chances are good you have 126mm spaced frame and would have to up to 130 or 135mm to fit the newer hubs.
Quoted: 1607 Post(s)
Liked 2,216 Times
Correct me if I am wrong, but once the total got past 21, the description broke up. Or maybe it broke when the industry moved from freewheels to cassettes.
Bikes: Many
Many bikes are still marketed as the "total" number of chainrings x cogs (and I should have said multiplied chainrings by cogs, instead of adding, in my first response), although not usually road bikes. Still, it's about as important in general as how many watts your sound system "has".
Those who are experienced reference only the number of cogs (more correctly, sprockets) at the rear as the number of speeds. From there, you've either got a standard double, compact double or triple crank.
No one talks about Campy's latest drivetrain as a 22 speed (two chainrings and 11 cogs). It's an 11 speed drivetrain.
