From a Compact Double to a Triple
Lula Mae = 15 lbs.
Bikes: 2011 Trek Madone 6.5 w/SRAM Red 22
Are upgrading components of any existing bike or planning on moving to a whole new ride?
New bike. The compact double is a lot less convenient than I'd imagined. I end up cross-chaining a TON.
I figure when the time comes to replace the front crank, which should come in two years time, I'll do it then.
Lula Mae = 15 lbs.
If upgrading, you'll need a longer cage RD and either an FD for a triple and/or the need to raise the FD
a tad higher on seat tube. Your left shifter/brifter will need to be swapped out for one that can shift thru
3 chainrings; may need new shifter cable.
Lula Mae = 15 lbs.
Some triple crank owners I know like to have those chain guide catchers on their seat tube.
I ride a 50/34 compact crank w/12-27 cassette. Previous bike was a triple.
Also, I cross-chain like crazy...
My problem could be alleviated to a large extent I suspect by a rear cassette which overall had larger cogs.
I looked up the specs of my bike and apparently I have a 12-26 Sram 950 for the rear cassette.
Suggestions for something with slightly lower gearing? Is it possible to fit a mtb cassette like the hg50 onto it?
Senior Curmudgeon
Bikes: Miyata, Fuji
On my triple, a 53/39/30, I have a 12-27 cassette. I RARELY get off the 39 ring, in fact wore it out after 15000 miles! Even moderate hills were no problem with 39/27 combo. When I go to the real hill counrty I do use the 30 for up, and the 53 for down hills. I think the 12-26 will be fine for even fairly steep hills. If not you can always get a Shimano 12/27, or the new 11/28. I also have a 50/34 compact on my other bike with a 12-27 cassette, and rarely get out of the 50, so I also crosschain A LOT.
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 25 Times
... Seriously you need to start giving us more information. Start by listing the complete specs for your bike.
relevant specs are
50/34 compact crank
12-26 Sram rear cassette.
I think that the long length of the chainstay might help a little in cross-chaining. I'll often go as high as like gear 6-7 on the 50t
Bikes: 2010 Specialized Roubaix comp (SRAM Rival), 2009 Trek 7.3FX, Early 80's steel frame Suteki road bike
When I was buying that bike, I used Sheldon Brown's gear ratio calculator to compare a compact vs. triple (assuming the same cassette), and I really only gave up a couple of lower gear ratios by going with the compact. IMHO, worth it to have a simpler FD to maintain...I hate having to adjust the FD on my hybrid (which has a triple).
Depening on what you consider to be "slightly lower," you may not need to go to an MTB cassette. I run an Ultegra 11-28 cassette with a compact crankset on my road bike, and I have all the low end I need for my New England hills. That was an upgrade from the stock 12-27 that came on the bike, works fine w/o changing the RD.
Thoughts on replacing the 9 speed with say, an 8 or 7 speed? I don't get the purpose of the 9speed, honestly. I usually end up shifting two gears at a time, and it seems that the only difference between the 9 and the 8 is that the 9 has a 12-13-15 while the 8 has 12-15
heck, this 6 speed may beall i need
https://www.amazon.com/Sunrace-Freewh...9033297&sr=8-9
Liked 7 Times
...and yet another question.
Multiple cog close ratio cassettes help the rider maintain a higher effeciency cadence. This is especially important on flatter rides when drafting or when fighting a strong headwind.
headtube.
Well, if you don't get much benefit out of close gear spacing, you might also think about a wide range double. An MTB 11-32 or 11-34 cassette and MTB derailleur in back leaving your compact up front, would be another way to eliminate your cross chaining issues and would remain compatible with your current shifters.
Fred-ish
I changed my Fantom CX to a triple with a 11-34 cassette for some touring and winter riding (needed high cadence in cold weather due to knee and back issues).
IIRC, I needed to switch the rear derailleur to a long cage model. I used a deore rd. I also changed the fd to a triple and bought a new chain.
FWIW, if I lived out west and climbed a lot of mountains, a compact would probably work out great. With the constant up and down where I live, it would be a hassle. A compact will also never offer the range or tight gear spacing that you can get with a triple.
If you make the switch, you might need to tighten the B-screw (or screw it in from the back) to get more clearance between the biggest cog and the jockey pulley. It's counterintuitive, but when switching to a larger cog you can sometimes use a shorter chain to pull the jockey further away from the cog. If your chain is currently longer than necessary, you could shorten it.
That being said, going to a bigger cassette might not help that much with cross-chaining when you are on the smaller chainring. Tooth counts at the high end of the cassette are typically the same across road and MTB cassettes (11 or 12 teeth). The change will mostly be at the bigger-toothed cogs on the cassette, which will make the middle cogs more usable with the bigger chainring. That's not so helpful if you're riding in a city, with frequent starts and stops. Perhaps another solution is to use a small chainring with more teeth (say, 38t if you're currently using a 36t).
FWIW, I explored the same options when I started riding my Surly Cross Check. I didn't yet appreciate the close 12-25 cog spacing and uphills were killing me (a probable case of swine flu didn't help). I emailed Surly to ask about changing to a triple, but they very politely suggested that I HTFU instead. They were right, and now I'm very much enjoying the stock setup. So maybe you should try things out for a while before buying a ton of replacements.
So in conclusion, the answer is no, since I'm not keen on replacing derailleurs.
Weirdly, I also haven't been able to find many 48t/36t front cranks.
Elitist Troglodyte
Bikes: 03 Raleigh Professional (steel)
Your instinct to change to a triple is the right one. When you need wide gearing, it is the nature of a compact to cross-chain. There's just no way around it.
Unfortunately the conversion is not an easy one. You'll need the crankset, probably a FD, possibly a right shifter, and possibly a RD. (You still haven't told us enough about your components to be able to say for sure.)
Changing RDs isn't a big issue, btw.
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
- Will Rogers
