Aerospoke to replace deep v?
...carp..car..carp...
Bikes: https://velospace.org/node/21758, https://velospace.org/node/21767
Well, ive untrued my front velocity deep v flying off curbs during deliveries. Are the aerospokes wheels strong enough aka stronger than my dheep v. I got a B43 for the rear but I perfer a front brake in case of emergencies due to all of the stupid drivers around my little city so a B43 front is out of the question for me. I refuse to take a brake to one. sooooo aerospoke? I just dont want to start truing a deepv and get it even weaker....
You are confusing a few issues here--- sounds like your wheel wasn't properly built if it won't stay true. Secondly, truing it won't make it weaker. Thirdly, aerospokes cannot be trued-- and you might want to take a close look at how "true" it actually is before buying one. Many are built with a noticeable wobble.
Live without dead time
1- truing won't make it weaker, in fact you should look at getting it trued by a proper wheelsmith and you might find it's plenty strong for your purposes.
2- no an aerospoke won't be super strong for abuse, can't be trued and isn't a great choice for your applications.
3- a sun CR-18 laced 36 spoke 3-cross will be extremely strong. Like indestructibe strong
Comanche Racing
Bikes: Presto NJS build, Specialized Allez Pro w/ full Dura Ace and Ksyrium SLs, 1990something Specialized Sirrus
^^+1 to what they said^^
Bikes: 1990 Waterford Paramount, 1986 Pinarello Pista 195? Raleigh 3sp, 2001 Surly 1x1, 2014 Canfield N9, 2015 Canfield Balance, 2013 Rocky Mtn Flatline, 2012 Intense SS2, 2014 Transition Klunker, + more!
Ditch the aerospoke idea. Go have your wheel properly trued by a wheelsmith (like elTwitcho said) an forget about it. Your veep can withstand some abuse.
If you insist on a different wheel. (elTwitcho again to the rescue) The Sun CR-18 36spoke is a bulletproof setup. I have that rim/spoke count on my winter beater. I love them.
Bikes: '07 Pista, '09 Fantom Cross Uno, '8? Miyata, '67 Stingray, '0? Zoo mod trials, Tallbike, Chopper, '73 Schwinn Collegiate, '67 Triumph Chopper, '69 CB350, '58 BSA Spitfire, '73 CB450
Aerospokes + abuse....
Bikes: Leader 722ts
in the time it took you to post this twice under slightly different titles you could have searched for your answer.
Bikes: De Rosa Planet, Shogun Kaze, Jamis Sputnik, Redline 925
Pants are for suckaz
Bikes: Hardtail MTB, Fixed gear, and Commuter bike
Here is the hub I used. Bombproof.
my quads hurt...
Bikes: 2010 langster, 2009 fuse 2, 2009 transition
supervillain
Bikes: EAI Bareknuckle, 1981 Gios Aerodynamic, Giant Boulder
don't get an aerospoke, they weigh over 9000 pounds
Bikes: Schwinn, Mercier Kilo TT, Mercier Galaxy
True it yourself...I have deep V rims... i made them stronger not weaker!
Bikes: Bianchi San Jose, fixed
I just wanna ride
Bikes: 2013 BMC Impec
ya, like people have said, having a rim trued right will make it stronger and less likely to keep warping.
But if you want that new rim, H+Son is soon to release a 43.3mm deep rim (f**k you velocity) that is 22mm wide, which would nicely fit a 25mm tire up front, which would also help absorb some curb jumping shock. I doubt it will have a braking surface though.
Riding Engineer
Bikes: Kiyo Kiyo Kiyo
I found Aerospoke supposedly released that it's about 2.5kg. ... Wait someone said it's about 1.5kg.
Anyone actually know it's exact weight?
Last edited by Tomo_Ishi; 12-06-09 at 03:20 AM. Reason: Apparently wrong number. Sorry.
I just wanna ride
looking them up I got this from an actual owner
Weights may vary slightly.
700c Clincher:
front- 1274g
rear- 1440g
I also found this weight
1420 front.
1608 rear.
700c Clincher:
front- 1274g
rear- 1440g
1420 front.
1608 rear.
IRL Banhammer
I want to say that I was able to EP one through my shop, I got it delivered, took it out of the box, held it for about 30 seconds, packed it back in the box and put it on eBay... the front wheel weighed as much as my entire road wheelset (AM Classic)! It also looked very cheap. From my (brief) inspection, it appears they use an all-metal design then just press two carbon halves together. You can see down the middle where this occurs, it looked very cheap and also a great marketing con to advertise a carbon-pressed metal-core wheel as a carbon wheel.
saddle sores bike club | prepare to be rode
Quoted: 7 Post(s)
It's not carbon, it's a composite (plastic mix really). Don't know how it compares to a similar material like Eastons' CNT products. But the Eastons are very light, and strong. These are just strong and heavy.
If you like the style, then go for it. Don't be under the illusion that they are performance wheels.
Simple as that.
Simple as that.
