Tube repeatedly bursting at valve stem
Bikes: 2007 Jamis Aurora
I have a 2007 Jamis Aurora with Alex ACE19 rims. I inflate my tires once a week to 110lbs (yes it is printed on the tire sidewall), but every few months the valve stem goes pop while I'm pumping or removing the pump from the stem. I have padded the stem hole in the rim with some duct tape with no success. It went pop again this morning and I had to walk to work. Does anyone have a solution to this problem?
Liked 7 Times
Underinflation can cause the tire to slip on the rim and damage the valve stem. Fully inflate your tires before each ride.
Do you use a frame pump or a floor pump. The rocking motion of a frame pump can cause damage to the valve stem.
Al
Al
Bike ***** Poster
Bikes: Velo Orange, '91 Wicked Fat Chance, '99 Sycip Hardtail, '02 Sycip Pave custom, Benotto fixed, a playafied Bridgestone MB-3 and a bunch of hacks, beaters, townies, and 'projects'.
If the valve hole is drilled for schraeder (car tire valves) and presta tubes are used without a rubber grommet, it could cause the tube to be resting against the sharp edge of the hole.
Bike addict, dreamer
I don't think the rims are schraeder, as the bike had presta valves when I bought it new. I think I might try a variation of the Presta Saver by making a rubber boot out of the old tube to slip over the stem of the new tube. My LBS also suggested sanding down the edge of the hole.
Thanks for the help everyone!
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
Inspect the tube failure; is it a laceration or a rubber failure/split? See also this thread:
https://www.bikeforums.net/showthread...ird&highlight=
Like I posted there, are you stuffing your tubes both sides at once away from the valve? Or down one side and all the way around.
Proper: https://www.youtube.com/watch?v=vXnTqP7Nd_o#t=2m11s
and max pressure isn't necessary unless you weigh >200lb or ride only very smooth pavements but that's a whole nother can o' worms.
Just in case it didn't make sense, if you're using a hand-pump to top-off your tyres to 110-psi, you deserve to get regular flats. Floor pumps only.
Guest
Bikes: I never learned to ride a bike. It is my deepest shame.
Liked 6 Times
+ 1 to DannoXYZ... frame pumps and mini pumps should be kept for emergencies only, as regular use tends to cause the tube to fail around the valve. A basic floor pump (~$20) is 100X better.
I put the valve nut on the inside of the rim. You have to make sure it doesn't ge trapped under the bead, but I almost never get torn valve flats.
Bikes: Klein
I popped a new tube at the valve last Summer when I pumped it. I figured I just pressed the pump head on too har and tore the tube at the valve. Since you mentioned that the failure occurs when you attach or remove the pump, maybe this is the problem you're having, too.
Bikes: jamis 2002 komodo, univega aplina uno, miele toscana 300, 1972 puch brigadier, Marin Sausalito
Quoted: 18 Post(s)
Liked 17 Times
+1 on putting a nut inside the rim as well as outside. old indian and motorcycle trick.
Take a 1-1/2 inch length of Velox rim tape or adhesive cloth handlebar tape, trimmed appropriately for rim width. Put a small nail hole in the middle of the 1-1/2 inch tape. Lift your existing rim tape/rim strip and put the 1-1/2 inch "hole buffer" strip over the valve hole with the nail hole centered over the valve hole and replace your rim tape/rim strip back over the top. When you press the presta stem down through the new hole buffer, the cloth tape will insulate the rubber/valve interface from any sharp edges, but you might as well inspect the hole while you're in there, before you apply the new tape. If you don't have an appropriate file, you can probably just run an appropriately sized Phillips head screw driver up and down the hole to take of any burrs or rough edges.
I used to do this with mostly favorable results, but had some extreme cold weather failures with this method. The extra cloth tape "hole buffer" method has worked better for me in the winter. I also don't tighten down my outside nut too much in the winter.
Quoted: 18 Post(s)
Liked 17 Times
the michelin 700x28 city tires ands tubes i ordered recently have no threads at all on the stem. maybe i have around 100 + plus miles on them with no problem. the last few weeks the temps have been in the mid 20 f range, lots of sand and salt about on the roads from some snow events. i run a 7 mile loop when ever i can get out. not many miles but all seems good. i use a floor pump once a week for 90 psi, tires are rated at 87.
Gee and all this time using only a frame pump and no flats and no nuts.... Sounds like a bunch of user excuses...
biciclista
Quoted: 5 Post(s)
Liked 6 Times
I've used exclusively frame pumps for the past 15 years without problems until this year. I have a 700c wheel that I've used with no issues for 4 years, then this year I got torn valves all the time when trying to pump to 120psi. I finally decided to buy a floor pump a couple of months ago and have had no issues since.
