Single pivot dura ace vs dual pivot
Bikes: 79 Peugeot UO8, 89 Peugeot Triathlon, 170$ Possibly a Raliegh Cross bike that I can kick your ass on...
So I am in need of brakes and I found some early 90's single pivot dura ace brakes for about 50$.
Anyway I am concerned about stopping power, not so much the weight issue.
My budget for brakes is around 100$, any suggestions?
Quoted: 2026 Post(s)
Liked 1,096 Times
"Stopping Power" is the same for any decent brake, single or double pivot. All of them will lock both wheels of a bike and you can't get more than that. However, dual pivot brakes require less hand pressure for a given controlled stop or speed modulation and that can be very useful on long downhills where you have to apply the brakes frequently and for an extended time.
You should be able to find newer used double pivot Ultegra or 105 brakes, or even some earlier dual pivot Dura Ace brakes for well within your budget. One recommended upgrade is to fit what ever brake you get with Kool Stop Salmon pads.
Thanks!
Bikes: '93 Performance R203, '83 Bianchi 980
Tektros are great dual pivot brakes in the $50-60 range. Available in 3 lengths. Velo Orange has the nutted version, if you need that.
Quoted: 128 Post(s)
Liked 12 Times
I'm running single sivot brakes on one of my nicer road bikes. 105's from the early 1990's. They stop fine. The slight difference in mechanical advantage has two effects:
1. takes more hand pressure to lock up the wheel
2. the pads can sit a bit wider apart and thus give more space for an out-of-true wheel or for riding home if you break a spoke.
"c" is not a unit that measures tire width
Quoted: 128 Post(s)
Liked 12 Times
but it's not clear that your book is talking about DA brake pads from the single-pivot era (probably 20-year-old pads)
Liked 1,096 Times
What is the copywrite date on your reference? I agree Shimano's pads work well but the Kool Stop Salmon pads do also and, in my experience, somewhat better. I wonder if the book predates the Kool Stops.
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
If you think the koolstops stop well, especially in wet weather you really should try the green swissstops. I really have it against shimano "dura" compatible pads with the performance degrading "plow tip" feature.
nice idea, poor execution
No more razorblades. To say I am looking forward to them is an understatement.
I found some nice cond used shimano ultegra sl calipers for 60$
Liked 1,096 Times
