Bent Skewer
Bikes: 1997 Specialized M2Pro
Bent Skewer
In overhauling the rear hub today, I noticed that the skewer was slightly bent. I figure that that is not a problem. I'd like to keep it since it's the original Campagnolo part that came with my 1991 Bottecchia.
Should I replace it?
Thanks,
Thanks,
Quoted: 2026 Post(s)
Liked 1,095 Times
How bent is "bent"?
Bikes: '82 Giante super challange, 70 Gitane Tour de France, GT Gutterball
I bent the skewer on an old mailard hub, its bent at maybe like a 5-10 degree angle right around where the skewer leaves the axle (on the acorn side) I did however bend the axle which was the cause I replaced the axle and I still use the QR, shouldn't matter as its not a moving part and i've never had any problems with mine
I would not worry about it. You can straighten out your existing skewer in a vise , plus it is from a time period when steel was steel, not junk. Check the axle and the frame dropouts, to be sure.
What he said, just be careful not to wreck the threads in the vise, that gets frustrating quickly.
Bianchi Goddess
Quoted: 2926 Post(s)
Liked 2,922 Times
even if the OP terminology is correct I think it is hard to have a bent skewer without a bent axle. I would test the axle with another skewer to ensure it inserts without resestance. repairing/replacing a bent skewer is a waste of time and effort is the axle is bent.
Sugar "Kane" Kowalczyk
Quoted: 1572 Post(s)
Liked 643 Times
I'm thinking the skewer is probably OK. I've ben thinking of what could cause it to bend. Until you figure that out straightening or replacing the skewer is futile. If it was my bike, I'd be looking for a shop that has the necessary gauge to make sure your dropouts are parallel.
Old fart
Quoted: 3583 Post(s)
Liked 3,395 Times
Bent skewers usually happen when the wheel is removed from the bike and the projecting end of the skewer gets whacked. It's trivial to straighten such damage.
New Orleans
Quoted: 157 Post(s)
JohnDThompson is certainly on the money in respect to an Ebay Trek 820 that arrived recently. It was pitifully packed and the skewer was dinged when the box was crushed a bit.I had a spare, so I haven't bothered straightening it yet.
Yep, they get bent-and even bent you can manage to stuff them back thru the axle.
Charlie
Charlie
