Measuring, Cutting & Mitering Tubing
How does one measure, cut and miter tubing?
I saw lots of pictorial info on how to braze the tubing but nothing on how the tubes were prepped. There were extensive discussions about the cost of getting into frame building but no one mentioned the cost of the gages and tools needed to cut and miter the tubes.
Randomhead
Hacksaw and a good set of files will cost less than $100. You should get a good hacksaw, and good blades. Lennox makes good ones. I think we just talked about files recently. You want a half round bastard cut file that matches each tubing diameter.
If you go with a tubing notcher, get fine tooth hole saws. These for example Get mandrels from Strawberry or Paragon (UBI sells Paragon or order direct) There are two sizes of mandrels depending on the size of the hole saw, get one for each hole saw. I'm setting up my lathe to cut miters, but that's a bit of an investment.
Jet Jockey
Bikes: Cannondale CAAD9, Ritchey Breakaway Cross, Nashbar X-frame bike, Bike Friday Haul-a-Day, Surly Pugsley.
Good night...and good luck
Bikes: Ruckelshaus Randonneur, Specialized Allez (early 90's, steel), Ruckelshaus Path Bomber currently being built
I'm finding the trial and error process of finding a half-round file that matches each tubing diameter a bit of a trial. Does anyone have a source and stock numbers for good files that fit the diameters of 1", 1.125", 1.25", and 1.375" tubing?
Thanks
Pete
Thanks
Pete
Check this guy's video, he makes it pretty simple: https://www.youtube.com/watch?v=42nP42sbhEI&fmt=18
tubemiter.exe: https://www.ozhpv.org.au/shed/tubemiter.htm
