Outfitting my daughter - educate me on frame size please
My daughter is interested in racing bmx, and I want to get her rigged up proper. She is 9 years old, 4'6 and has a 22" inseam. Obviously the lighter the better when it comes to racing. However, I could use some direction on what size frame will fit her...mini, junior, expert,etc... Dont really have any bmx dealers in the immediate area, and I need a starting point.
Yeah. I Race.
Bikes: Custom Race, 2007 GT Bump, 2007 Gt Powerseries Pro, Dyno VFR
I think I would probably go with a junior. After looking at a few sites, the Juniors' standover heights were just under 22", and you want her to be able to touch the ground. But some bikes are sized differently so even a small expert might a fit her. It's easiest to go to a bike shop or the local track to find out what size she should be riding.
I would suggest a Redline Proline Mini. 20.4" stand over. https://www.redlinebicycles.com/bikes...0-proline-mini
Frame Redline Mini 20" / 6061-T6 Aluminum / Machined Headtube and Euro BB, 3-D Forged Dropouts
Fork Redline Mini/Junior 20" / Chromo Steerer & Legs
Handlebar Redline 19.25" W x 2.5" T x 10° Back x 2° Up / Aluminum
Stem Redline Hollowpoint Mini Aluminum 40mm
Grips Redline Hex Mini
Headset VP Threadless w/Aluminum Top Cap
BB Set VP Euro Cartridge
Crank Microline 145mm 3-Piece
Chainwheel 37T
Tires Tioga PowerBlock 20 x 1-1/8"
Rims Sun M13II 28H w/Eyelets
Spokes Radial-Laced Front / Stainless Steel
Front Hub Redline Aluminum
Rear Hub Redline Cassette Aluminum
Rear Cog Redline 3/32" X 14T Cog
Brake Tektro 926AL V-Type
Brake Pads Tektro
Lever Tektro 317A
Cable Tektro
Chain KMC Z30
Saddle Redline Microline Mini w/Integrated Aluminum Post
Seatpost 22.2mm
Seatpost Clamp Redline Proline Aluminum 25.4mm
Pedals Redline Jr Aluminum Cage/Body / Chromo Spindle
Extras Mini Padset / Redline Single-Bore Chain Tensioners
Weight 15.5 lbs
Headtube Angle 72°
Seattube Angle 69°
Toptube Length 17.8"
Chainstay Length 13.1"
BB Height 10.5"
Standover 20.4"
Chainwheel 37T
Brake Pads Tektro
Lever Tektro 317A
Cable Tektro
Chain KMC Z30
Seatpost 22.2mm
Weight 15.5 lbs
Headtube Angle 72°
Seattube Angle 69°
BB Height 10.5"
Standover 20.4"
