Spoke Length variance allowed?
Road cyclist
Bikes: Trek 400, Raleigh Panasonic, Barracuda Magma
Hi,
Having built a few 3 cross wheels I wanted to try something different just for the fun of it.
I've got a pretty sweet price on some 290mm spokes, the front wheel is 32h, want to lace it 2 leading 2 trailing, and the rear is 36h, want to lead it 3 leadng 3 trailing.
Now, i've calculated the front to need 290.6mm spokes, so they'll be fine, but the back requires 292.6mm.
This on either side add's up to 5mm of a difference.
Will I be able to use 290mm spokes on the 36h wheel that requires 292.6mm? I'm using standard. 12mm nipples that protrude roughly 6.5mm out of the rim.
The spokes are threaded for around 10mm at the end of the spoke.
Hope this is enough info,
Cheers,
Paul
Cheers,
Paul
headtube.
If it's a really good deal on 290 spokes it could work if you get 14mm nipples for the rear wheel. Otherwise you might not engage enough of the threads inside the nipple.
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 25 Times
Hi,
Cheers,
Paul
Cheers,
Paul
If you've measured everything right, it's +/- 1mm tolerance. 290's will not work for a 292.6 (293). You will have little to zero tension on the rear, left side. Even if you tried to compensate by overtensioning the rear drive side. Do not do this.
Road cyclist
I forgot to mention the rear hub is a single speed hub with equal diameter flanges. The same distance from the centre.
I understand you need 2 different sized spokes for freewheel hubs and freehubs. But this is a fixed fixed hub, so it's symetrical.
Reckon it'd be alright now?
Road cyclist
(Btw the flange diameter in this IS measured centre to centre of opposite holes, not to the edge as pictured, that's just a quick template I made.)
The rim has an ERD of 608mm
cab horn
Quoted: 42 Post(s)
Liked 25 Times
There is no way that blue measurement is 135mm. It doesn't even include either cone/locknut on BOTH sides. That hub would fit on NO bike. And again, 290 will not work on a spoke length spec'ed for 293, regardless if it's dishless.
Road cyclist
Regardless of the picture, the measurements I've taken are fine i made that in a hurry and clearly misplaced some of the lines.
So on a dishless wheel with a symmetrical hub, 290mm spokes wont work with 12mm nipples, for a wheel i've calculated needs 292.6mm spokes? And there's no way around it other than to get 292mm or 293mm spokes?
Is it better to round up to the nearest whole number than round down?
Useful Idiot
Bikes: Giant RS940, Schwinn Sports Tourer
You can round up or down depending on your ERD measurement. When I use the manufacturer's ERD I usually round down and when I measure the ERD myself to the bottom of the nipple screwdriver slot I round up. Rounding down by 2.6mm is too much IMO.
Liked 7 Times
It's always better to round down to avoid running out of threads. This is more important on wheels on rear wheels with high driveside tension.
Retro-Direct Fan
Generally, one would calculate the optimal length, then round to the nearest available spoke length. Depending upon the obscurity of your length requirement & spoke type & the extensiveness of your suppliers inventory, this will generally mean rounding by less than a mm, but sometimes more. 2mm off is about the maximum that would typically ever be required, and I 'd generally recommend against exceeding it.
On the other hand, you'll probably be fine. They'll reach, but you'll have a bit less thread engagement than is optimal; slightly more chance of breaking a spoke. You're going 3-leading, 3-trailing, so obviously "optimal" is not the target.
I have build very nice 3-cross wheels where I wouldn't have dreamed of being off by 2.6. I have also laced the cheapest spokes I could find to a beat-up coaster hub in the very 3&3 pattern you describe. I say, go for it.
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
Nope...wouldn't do it...don't use nipples as a spokes...nipple barrels will eventually break...unless you are certain that the spoke ends are getting into the rim a mm or so after final tension.
Also if those spokes are DT or Ritchey...I wouldn't be surprised if they came out of the box measuring 289.5 mm...leftover stocks of DT and Ritchey spokes from the 80s and 90s still show up with spokes .5mm under the box labelled size.
Check with a Park Tool or Wheelsmith spoke ruler...
=8-)
=8-)
Road cyclist
Thanks a lot for the advice guys. 290mm is a pretty sure length to buy though, I've used them before and now again, so i'm sure i'll use them in future.
I think I would need longer spokes for the rear after reading some, it just means I'll probably end up buying some cheapo spokes cut to length instead of the double butted oens I wanted, but then again, as I said, I'm only doing this for a bit of fun and for a change. As for 3leading 3 trailing needing longer spokes, Iknow quite a few guys who have bought standard 3 cross cheap wheels and re laced them for the fun of it with no problems due to spoke length.
As was said, i'm not going for the best wheel I can build I just want a little project to work at over the break. I think I'll still get the 290mm spokes for the front and see what I can get in the mean time for the back and keep an eye out for some better spokes, and if they're cheap enough get them and relace the whee, no harm done.
Again, thanks a lot for the info guys, much appreciated,
Cheers,
Paul
Cheers,
Paul
Quoted: 1074 Post(s)
Liked 295 Times
I 've had no problems compensating for shorter spokes with longer nipples though.
tmh657
Bicycle Mechanics
22
07-23-14 07:54 PM
