Square BB question
Rolling along
Square BB question
Are they all alike? I am planning to swap Cranks. the current set has Shimano MC08 cranks. I was planning on buying
https://www.bikeparts.com/search_resu...p?ID=BPC332188
Does anyone froesee any problems w/ a direct swap?
Thanks!
Thanks!
Rolling along
Ok, I will have to look in to that! I don't know the length of the orgional spindle yet so I will have to remove it tonight and measure.
Thanks
Thanks
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12635 Post(s)
Liked 7,528 Times
Ooops, I got current and new crank mixed up, this should make sense now:
Current crank mc08 likes a 110mm spindle for a 47.5mm chainline.
possible new crank fc-m410 likes a 113mm spindle for a 47.5mm chain line,
Last edited by LesterOfPuppets; 01-13-10 at 03:48 AM. Reason: mixed up new and existing cranks
I have senior moments...
Bikes: Many
If your bb is as Lester looked up, and you increase chainline by 1.5 mm (1/2 of 3mm difference in spindle length) you'll have a 49mm chainline. The current crop of Shimano external bb type cranks are 50mm chainline, so likely you won't have a problem with just swapping cranks...
Rolling along
nevermind my googlefu is getting better. I just didn't know to ask about the length of the spindle. I'm such a newb.
Rolling along
Now that i reviewed my options, would these be a better choice? I was planning on staying Shimano, but I am having trouble finding a good fit.
Sugino Impel 150X triple mountain bike crankset is 7- and 8-speed compatible.
- SuperShift chainrings with ramps, pickup pins and special tooth profiles for shifting performance and less chainsuck
- Black outer ring, silver steel inner rings
- 7/8-speed compatible
- 4-arm, 4-bolt spider
- Color: Silver
- Weight: 690 grams
- Spindle Interface Type: Square Taper JIS
- Spindle Length: 113, 110mm
- Pedal Spindle: 9/16-inch
- Bolt Pattern: 4-Bolt
- Chainring BCD: 64, 104mm
- Arm Length: 170mm
- Rings: 22-32-42T
- Crank / FD Type: Mountain Triple
- Intended Use: Mountain
- Chain Compatibility: 3/32-inch
- Crankarm bolts not included
Bikes: Peugeot Hybrid, Minelli Hybrid
If you put a M410 (which takes a 113 spindle) on a 110 spindle it will be 3 mm further in, which may result in granny ring hitting the chainstay.
Insane Bicycle Mechanic
Quoted: 788 Post(s)
Liked 688 Times
Google... phoo...
Jeff Wills
Jeff Wills
Rolling along
So if I am looking at the specs for a replacement crank set, what numbers should I be paying attention to? The Shimano specs state:
FC MODEL # CN SP LGTH 47.5 CN LINE SP LGTH 50 CN LINE SQR TAPER INTERFACE
FC-MC08 110 113 X
then I should be ok swapping in:
Thanks everyone again
FC-MC08 110 113 X
Bikes: everywhere
Liked 7,528 Times
It's tough to say. That Sugino has some giant chainrings by modern standards. Does it seem like there's enough room for your chainstay to accommodate bigger rings?
Do you know the length of your current BB spindle yet?
Bikes: Many
FC-MC08 110 113 X
FC-MC08 110 113 X
Bikes: everywhere
Liked 7,528 Times
The Impel 150x I saw had 28-38-48 rings on it - totally pre-1990 style. Perhaps they have compact also.
Ah, yes I see some 24-34-42 available now.
Go for the smaller ones to ensure clearance. Unless you need a higher gear and/or run a 13 or 14 small cog in the back.
Rolling along
No, I had Cub Scouts last night w/ my son so by the time I got him home, washed, and in bed it was 9pm and I didn't want to mess w/ it. I have to work job#2 tonight-Fri so I will see how it goes and what time I get off. I have an old CC-1 crank puller so it shouldn't take too long (famous last words)
I do not know if it helps but here is a pic from the Trek Web Site of the bike.
Thanks again.
Thanks again.
Bikes: Many
Rolling along
Sweet!
OK Great news regarding the size!
I didn't have to work so I just snatched the cranks off. I was thinking it was going to be a tougher job than it turned out to be
Measuring the spindle questions. Do I need to pull the spindle? I am thinking I will need BB tool for that, huh? Once I get my batteries charged I'll take pics.
I was looking at the chainstay and I have about an inch of room from the 42t chainring to the chainstay. I was thinking about moving up to a bigger one but I'll stay w/ the size I have now to make things easy.
Elitist Troglodyte
Bikes: 03 Raleigh Professional (steel)
What is it you're trying to accomplish here?
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
- Will Rogers
Bikes: Many
Rolling along
I have a micrometer in inches I can measure each side w/ that.
No such luck w/ the stamp.
.731" +.676"= 1.407=35.7378 mm
Bikes: Many
What/how are you measuring? Even if you have a 68mm shell, that only adds up to 103.7378....or 108.7378 for a 73mm shell. What shell width do you have anyways?
Rolling along
I measured from the point where the shaft exited the housing, flush. Then to the outside
I
I___________________
I I
I---------------------------I
I___________________I
I
I<~~~~~.731"~~~~~~>
The shell is the part the BB is house I assume. Ok I'll measure.
Since I had sucess pulling the cranks I went ahead and pulled another from a smaller bike that had Acera cranks with the same tooth count and installed them and adjusted the derailleurs so it would shift. Somewhat anyway. The angle of the chain looked very extreem while on the 42t front ring and the 11t rear chainring. It was very slow shifting too. The front shifted fine.
I
I I
I
I<~~~~~.731"~~~~~~>
Rolling along
It measured 2 7/8" which comes out to 50.8 mm but you are right it seems kinda small. The bike is a 21 or 22" bike, so I guess I am measuring wrong.
I really appreciate the time you are taking. Even since I have swapped the other cranks i still would like to have the correct set on the bike. Once I get the correct size I will swap them back. I am trying to get a bike together so I can ride w/ my son on the weekends. My road bike wont cut the dirt trails he wants to ride lol.
Thanks so much again!!
Bikes: Many
Well, 2-7/8" is 70.8mm so I then checked your other conversions but found those correct...the shell width is just that, the width of the bottom bracket shell of your bike...don't include any part of the bottom bracket cartridge.
PS the size frame has nothing to do with shell width...mountain bikes are almost always 68 or 73 mm shells....
