Derailleur Lubrication
Bikes: Ross Mt. Hood, Fuji Odessa, Schwinn Continental
I have my wife's Trek 830 torn down and everything is getting a clean-up and lube. I gave the derailleurs an ultrasonic cleaning and wonder what you all use for lubing the pivot points. In the past I've sprayed mine down with silicone and seemed to have good results. I've only lost one derailleur to pivot point wear. But I'm not familiar with all the new synthetic lubes that are available now. Any other suggestions?
Thanks,
Walt
Thanks,
Walt
Quoted: 7 Post(s)
Are you talking about the main pivots that screws/hangs onto the frame and the cage? If so, the springs in those should be overhauled after an ultrasonic cleaning...
Quoted: 5781 Post(s)
Liked 2,576 Times
Any light oil is fine for the pantograph pivots, but the upper and lower bodies need something more substantial. Usually the spring is surrounded with grease which you probably either washed out or contaminated with your ultrasonic cleaning. You need to either dis-assemble and re-lube these parts or try to wick some heavier oil in, possibly diluted with a solvent as a vehicle.
FB
Chain-L site
FB
Chain-L site
If you stuck the whole derailleur in an ultrasonic cleaner, then it needs to be taken completely apart (if it wasn't already). The factory puts grease in the two main pivot areas. The pulley bushings are also greased, by I prefer a frequent application of a good spray lube rather than grease. Any good oil is sufficiennt for the other pivots .
Oil, any oil, and do it often, don't wait until you going to ultrasound the thing. Every time you wash your bike or have it up in the stand, put a drop on the der pivots and oil the pulley bearings, same with brake pivots. A little oil, often.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Yes, the springs are re-greased. The bike is an attempt at getting my wife out and riding more. She always compained that her old bike was a little too tall, so I rounded up this Trek with a 16.5" frame and am doing a complete overhaul so it'll be ready for spring. Thanks for the responses. I'll give the Tri-Flow a try.
Walt
Walt
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
I use "Finish Line" dry wax lubricant that seems to really get into the joints and pivots good on my brake caliper and derailleur pivots because of the light suspension fluid it is in. Really felt the difference before and after I applied the lubricant on my just finished restoration project recently.
Chombi
Chombi
la vache fantôme
Ultrasonic cleaning? Overkill any? I prefer to use a dry lube, like teflon, for derailleurs as not to attract any more dirt and grime. I can see where small amounts of tri-flow would work really well.
C://dos
C://dos.run
run.dos.run
C://dos
C://dos.run
run.dos.run
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
:thumbsup:
Always Learning
Bikes: Very Upgraded Denali 63.5cm
Quoted: 86 Post(s)
Oil, Grease, Silicone, Teflon??
I just recently replaced the bottom level Shimano DR that came with my bike with a Shimano Alivino. The factory grease that came on the pivots is a greenish-yellow and thick. So maybe a waterproof grease is the way to go...??
Expired Member
Quoted: 3672 Post(s)
Liked 5,427 Times
There is something below Alivio? That loop is cute!
Always Learning
Quoted: 86 Post(s)
Expired Member
Liked 5,427 Times
Was a joke! I figure if you fess up to riding a Denali you have a pretty thick skin
Quoted: 1572 Post(s)
Liked 643 Times
Derailleur lubrication?
I used to worry about things like that maybe back in the '60's. Now I just use a rag or Q-tip or something to clean them up a little. I won't say I NEVER lube derailleurs anymore, but it's certainly a rare thing.
Always Learning
Quoted: 86 Post(s)
The POS Denali got me into the 'Game'. I've grown to like the bike after many $$$'s worth of upgrades. The only things that are 'as built' are the dropdowns, brake levers, and bar tape.
Someday I'll have a sexy Italian looking ride........
I soak a RD in diesel fuel for about a week. Agitate it with long handled pliers. Scrub it with a toothbrush. Then, I'll hang it up to dry for a day. Then I drop it into a tub of automatic transmission fluid for a day or two. Then, let it it hang for a while until all the ATF drips off. After installation they run smooth as silk.
