what to do with hub shell?
It's got electrolytes!
Bikes: Self-designed carbon fiber highracer, BikesDirect Kilo WT5, Pacific Cycles Carryme, Dahon Boardwalk with custom Sturmey Archer wheelset
So I thought I was buying this drum hub (Sturmey Archer X-FD) and it turns out I only bought the hub shell. Now I still need the hub and I don't know what to do with the shell.
Can anyone tell me why they sell hub shells separately? I'm not sure if I should:
A) Buy the complete hub and keep the shell as a spare.
B) Buy the complete hub and return the shell.
C) Buy the internals and install them in the shell.
Bikes: NOYB
I'd pick B.
Sometimes a shell will break at the flange due to being in an accident or whatever, but it's not a common thing at all.
Piecing together a hub one part at a time is the most expensive way with the biggest amount of hassle.
As far as piecing together the hub, I was thinking this might be a good opportunity to upgrade the bearings.
I have senior moments...
Bikes: Many
B sounds like a good way to go, although if C made financial sense and you don't mind assembling it isn't so bad, then there's A and you could use the spare as a condiment shaker until needed for hub duties....a la Chris King https://www.universalcycles.com/shopp...s.php?id=33279
afraid of whales
Quoted: 347 Post(s)
Liked 5 Times
There's XFDs on ebay from a guy in Milwalkee, I purchased a XFDD from him a few months ago:
https://cgi.ebay.com/Sturmey-Archer-X...item5638aa8ca8
for a few bucks more you can have a front generator too:
https://cgi.ebay.com/NEW-Sturmey-Arch...item5638aa941d
here's an XFDD in stack at Universal:
https://www.universalcycles.com/shopp...&category=3680
I see this hub's price is going up, I could of had an XFDD last summer for $65, now when it's available it's more like $75~$85. Same thing happen to the SRAM i-Light hub.
Newer versions are sealed, my XFD from '84 is shielded.
I think I'm just going to return the shell I bought since there doesn't really seem to be much use for it. I mean, who the hell would try to reuse the internals after catastrophically destroying the shell? Oh well, live and learn.
