Is chain rub on the front deraileur wall normal ?
Bikes: FUJI Nevada 1.0 2009
I have a MTB with a 3 x 8 drivetrain setup and when placed in the tallest gear combo (biggest cog up front, smallest cog back) the chain rubs against the front deraileur's wall, or side, whatever you call it. Is this normal ?
Liked 6 Times
No, this is not normal at the gear combo you described. You need to do a front derailleur adjustment. Go to Park Tool's website or Bicycletutor.com to see how to adjust the front derailleur.
Quoted: 2026 Post(s)
Liked 1,095 Times
A properly adjusted front derailleur should not let the chain rub on the inside of the cage (that's what it's called) plate in the smallest cog and largest chainring. An adjustment to the cable tension should correct it. If the cage won't move any further outboard, the high limit screw can be loosened slightly.
I'm using this video: https://bicycletutor.com/adjust-front-derailer/
And I wanna know something. At 2:45, he talks about using the shifter barrel adjuster to eliminate chain rub on the sides of the cage. Is this the only adjustment I have to do out of all others shown in the video ? My gears shift just dandy, the only problem is the chain rub, and I don't wanna mess up my gear system by trying to fix something that didn't need to be fixed.
Also, if the chain is rubbing on the left side of the cage (when looking at it from the position of sitting on the bike) do I have to turn the shifter barrel adjuster Clockwise or CounterClockwise ?
Great State of Varmint
Liked 15 Times
After properly adjusting the cable to your front-derailleur (FD), after riding a bit - the cable will stretch and the cage of the FD may well start rubbing. Now you can loosen the cable anchor-bolt and pull the cable tight again and secure the bolt with 48 - 60 ip. OR you can have installed an inline barrel-adjuster and give it a small tweak to re-adjust the cable without even getting off the bike. Or slowing down.
Here are the barrel-adjusters I recommend:
https://www.biketoolsetc.com/index.cg...rrel-Adjusters
Here's one ready to roll:
Quoted: 5703 Post(s)
Liked 2,430 Times
There are two adjustments needed to manage the outermost position of the FD cage. The outer (H) limit screw which, as its name implies, determines how far the cage can move. And the cable tension, or trim adjustment which actually controls the position with respect to the lever position. First test the limit position by actuating the FD directly with your hand, or by pulling the wire away from the downtube to see if it will move farther out. If not, back off the limit screw and test again until you've solved the rubbing problem. Next use the adjusting barrel to increase the cable and move the cage out to the desired position.
When you've adjusted the trim based on the outer/outer combination test FD shifting and trim for the other chainrings. You might have to readjust the trim for the best all around performance rather than the one combination only. Sometimes a bit of compromise is needed.
FB
Chain-L site
FB
Chain-L site
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 25 Times
cab horn
Quoted: 42 Post(s)
Liked 25 Times
Decrease tension on the cable moves the cage to the "left" - which is clockwise on the barrel adjuster. If you actually viewed the video, he's talking about adjusting the cage in the *middle* ring, which means limit screw have NO EFFECT.
Take the garbage you post and put it elsewhere and learn to read.
bloodbox
Bicycle Mechanics
3
08-03-17 05:01 PM
