View Poll Results: Do I want a Hollowtech, Octalink or Square taper Triple Crankset
Hollowtech, It's troble free
14
43.75%
Octalink works great, no worries
3
9.38%
Square taper is ideal for a triple crank
15
46.88%
Voters: 32. You may not vote on this poll
Triple trouble; do I want a Hollowtech, Octalink or Square taper?
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
I'm selecting a modern 9 or 10 speed crank for a 1987 Trek 400. I want a triple for commuting and light touring. I like the operation of the Shimano 105 Hollowtech II road triple on my other bike. However the modern appearance and chainline are less than ideal.
A NOS 105/Ultegra Octalink 9 speed triple will look better on my vintage bike and will have a better chainline than the modern Hollowtech II triple. Is the Octalink BB & Crank as trouble free as the modern Hollowtech II?
How about good-old square taper? Sugino makes a good looking touring triple that has the ratios I want. Is Square taper reliable?
While claims for better reliability might have been brought up with the new BB designs, real world tests have shown that they are all about as reliable as the next. The biggest difference in that for external BBs, you can often replace just the cartridge bearings and reuse the shells. Square taper BBs can also be had with replaceable bearings (though most are not). Square taper allows adjustment of chainline through different length spindles which is impossible with the other designs. External bearing cranks are the easiest to R&R though.
It really doesn't matter much in the end IMO. I'd base your BB decision on which crank you choose, not the other way around.
Quoted: 2026 Post(s)
Liked 1,096 Times
I've currently have square taper cartridge bottom brackets and Octalinks on several triple cranks. From my experience I have concluded:
1. Shimano cartridge square taper bottom brackets are VERY satisfactory. I've gotten over 25,000 miles on a couple of Ultegra (UN-7X) and 105 (UN-5X) bottom brackets with absolutely no problems. A couple were still in good shape when retired for other reasons. I have a Campy Chorus triple square taper cartridge bb on one bike with 12,000 miles and it seems perfect.
2. Octalinks are also perfectly satisfactory. I currently have Octalink triple bb's on two bikes, one an Ultegra BB6500 (no longer in production) and one a 105 BB5500. The 6500 has over 25,000 miles and is still in excellent condition. The 5500 is relatively new with about 5,000 miles but no problems at all.
They are both good designs and I don't think you will make a mistake with either.
You will hear a lot of bad things about ISIS bottom brackets, which are a patent-beater design similar to Octalink. Since ISIS is a public domain design it was produced in many qualities. Some of these bottom brackets were very unreliable and gave the entire concept a bad name. Since it is similar to Octalink, there have been those who condemn the Octalink design also. That's not correct.
Medicinal Cyclist
Bikes: 2003 Klein Q Carbon Race; 2009 Giant OCR-1
The Hollowtech is incredibly easy to install/remove/maintain compared to the square taper, IMO. Not to mention light
Elitist Troglodyte
Bikes: 03 Raleigh Professional (steel)
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
- Will Rogers
Elitist Troglodyte
Crappy small bearings that will go 25,000 miles and more?
Granted that there is a theoretical advantage to larger external bearings, but that in no way makes Octalink bearings "crappy". There is also a theoretical disadvantage or two...
- Will Rogers
- Will Rogers
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
I know for sure mega-exo BB suffer from poor dust seals.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
I love my Suntour Superbe Pro cranks with square taper BB. Alas, I don't think they came in triple. But here's some that would look great on an 87 Trek
https://cgi.ebay.com/SUNTOUR-SUPERBE-...item45f094bfd8
https://cgi.ebay.com/ws/eBayISAPI.dll...=263602_263622
Quoted: 12192 Post(s)
Liked 1,496 Times
Sugino has the ratios you want. I have a couple of them. They are good, Sheldon liked them.
Sounds like a plan to me.
Kid A
Liked 5 Times
I've always had good, long performance out of shimano basic square-tapered bb's (just like the guy above said). Not complaints whatsoever.
Currently I am running a hollowtech II Shimano SLX triple crankset/bb. Easy to install, seems decent - no long term reliability testing yet though.
Liked 5 Times
the only issue I would have with square taper triple is that in order to replace or thoroughly clean the inner ring, the crank has to come off. In essence shortening the crank life every time you do that, since there's a limited amount of times you can install a square taper.
but seeing as how abundant and cheap square taper cranks are, a very minor, nit picky detail.
Spin Forest! Spin!
Bikes: I used to have many. And I Will again.
Quoted: 7 Post(s)
Liked 11 Times
Windy City means commuting in snow/slush during the winter. Touring means many miles away from home or a fully stocked bike shop when possible breakdowns occur.
I'd opt for a tried/true design, a sq. taper BB. There are lot's of options and any bike shop should have them in stock in case of emergencies. External BB can cause some clearance issues with certain triple combos.
A good quality sealed cartridge sq. taper BB such as a Shimano UNC-54 or better will last a long time and have good resistance to water/dirt. Perfect for a commuter bike.
This not a weekend racer. Latest and greatest technology and their price tags aren't necessary.
Single-serving poster
I have used the shimano UN-54 square taper bb for a really long time and it still spins great but i did end up with an ovalized left-crank arm after it came slightly loose.
Though I voted for hollowtech because i like the crank interface better(almost idiot proof) and the increased rigidity.... If you need a lower Q-factor though square taper is great.
Great State of Varmint
Liked 15 Times
For it's light-weight and trouble-free (usually - there are bound to be exceptions) operation - I'll go along with Hollowtech II for a triple. While I love loose-balls in my 1982 Campy Record BB on my PUCH - for my Hybrid I went Hollowtech II triple - A Shimano Ultegra 6603. It's sweet.
Liked 5 Times
Bikes: '93 Performance R203, '83 Bianchi 980
Liked 1,096 Times
That's not the fault of the bottom bracket. The crank arms weren't torqued adequately and ANY square taper crank/bottom bracket will fail that way if not assembled properly.
Expired Member
Quoted: 3671 Post(s)
Liked 5,424 Times
I have an Octalink 105 triple on my 94 Bridgestone RB2. I think the Octalink spindle is 118 +? which seems to give a not so great chainline. It's what I had.... If starting from scratch I would get the Sugino with lower gearing and a shorter bb spindle.
Liked 1,096 Times
If you want lower gearing on your 105, the least expensive way to get it is to replace the 30T granny with a 26T chainring.
Quoted: 910 Post(s)
Liked 288 Times
I've eliminated the Octalink type interface from consideration. The limited supply of V1 BBs being a concern. I like the old-school look of these cranks, but a purchase would be a bad investment IMO.
The Sugino XD600 triple with 46/36 & 26t chainrings provides a broad range for touring. It also looks much better on a 1987 steel-framed Trek than a modern Hollowtech II crankset.
Quoted: 118 Post(s)
Liked 50 Times
Quit being cheap and get a Phil Wood square taper. The ability to set your chainline exactly is worth it alone. The quality is unsurpassed. bk
Quoted: 910 Post(s)
Liked 288 Times
I decided on the modern Shimano Hollowtech II triple for my vintage. I'm not thrilled about the appearence on an older bike, but the iterface is trouble free and a 105 crank can be a bargain on eBay.
Michael
Michael
smitten by саша
Bikes: Salsa La Cruz with Rohloff; mutt parts
+1 on the Phil Wood. i just replaced my UN54, and honestly, i can feel the (better) difference. installation was a cinch, too. oh, and if i shine a bright light down my seat tube, i can just make out the shiny "Phil" logo.
