trouble with shifting gears on my bike...
I started using my bike again after i got back from vacation only to notice that it wouldn't shift into 1st gear unless i shifted into 3rd and then down to first again...does anyone know what the problem is that is causing this or how to fix it?
Bikes: Lots
Sounds like cable stretch. Turn your barrel adjusters at your shifters (little knob thingies where the cable comes out of the shifter) out counter clockwise in 1/2 turn increments with test rides in between to see if that helps. Shouldn't require more than 1.5 turns.
Also as JasBike said, lube the chain as well!
L8R
L8R
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, What a Ride!" - unknown
"Your Bike Sucks" - Sky Yaeger
um...i tried what u said a2psyklnut and it still didnt work...any other suggestions...btw i just got this bike back from the bike shop again after ure suggestion didnt work and the guy said it was fixed yet it still doesnt work...
Wood Licker
Bikes: Trek Fuel EX 8 27.5 +, 2002 Transition Dirtbag, Kona Roast 2002
That answer my question to some degree. Your cassette and chain might be badly worn. The teeth on the cassette might be fubar and the chain might be stretched. (look on the rear wheel...there is a thing with buttloads of teeth...thats the cassette)
you might need to get these changed to fix your problem
