tips for cleaning bike with mud?
Old 02-12-10, 03:55 PM
I rode my touring bike on my dirt roads and some parts of it had mud. My bike got muddy mostly on the wheels. I think my fenders helped it to not get muddy on the other parts of the bike. How should I clean my bike? How do you clean the gears and other parts around that area? Will water damage the gears? I dont want to mess up my bike by cleaning it wrong.
slipknot0129 is offline
Old 02-12-10, 04:07 PM
Quoted: 1074 Post(s)
Liked 295 Times in 222 Posts
When I've gotten my MTB good and muddy I start by hosing it down, then I bring out a bucket of hot water, some detergent and a discarded washing up brush and go at it. Then a rinse and then I'm done. When it's dry I might have a go at the chain and such with a rag and some lube. On festive occasions I bring out the cloths, the car wax and the old tootbrush for a more thorough cleaning.
Generally speaking bikes are quite rugged, and as long as you don't go aiming a high-pressure washer straight at bearings you can was them pretty much as you please.
dabac is offline
Old 02-12-10, 04:10 PM
So I wont damage it by using a water hose on the whole bike?
Old 02-12-10, 04:13 PM
aka Phil Jungels
Wanderer's Avatar
Bikes: 08 Specialized Crosstrail Sport, 05 Sirrus Comp
Quoted: 202 Post(s)
Liked 86 Times in 60 Posts
Rather than use mud, I'd opt for soap and water, along with liberal aplications of a hose.......
Wanderer is offline
Old 02-12-10, 04:20 PM
noglider's Avatar
Quoted: 7338 Post(s)
Liked 2,438 Times in 1,423 Posts
Mud is a terrible cleaner. Don't clean your bike with it.
noglider is offline
Old 02-12-10, 04:47 PM
Liked 4 Times in 4 Posts
Use a bucket. Spray from a hose tends to go places it shouldn't. Keep the pressure low.
garage sale GT is offline
Old 02-12-10, 05:07 PM
Real Men Ride Ordinaries
fuzz2050's Avatar
Quoted: 17 Post(s)
Liked 3 Times in 3 Posts
I'm inclined to just take a garden hose, put my finger over the end and have at it. Don't aim the jet at the hubs, and you should be ok. Or, let it be muddy.
fuzz2050 is offline
Old 02-12-10, 05:30 PM
rumrunn6's Avatar
Quoted: 5222 Post(s)
Liked 3,574 Times in 2,338 Posts
wait 'till it dries, then dry brush it and wipe with a towel and paper towels. you can get a nice assortment of brushes at grocery stores and hardware stores. keep a couple brushes just for the drive train
if you have to use water - use a spray bottle or some windex. the less water the better.
forced water spray can force water and crude into drivetrain parts which currently do not have that crud embedded in them.
in a pinch you can use a gentle water spray just keep it away from the sealed bearing areas such as bottom bracket and hubs
but seriously - consider the dry brushing idea first - it's very safe for the bike! :-)
rumrunn6 is offline
Old 02-12-10, 05:31 PM
dry brushing is more abrasive.
Old 02-12-10, 06:33 PM
rumrunn6's Avatar
soft brush
rumrunn6 is offline
Old 02-12-10, 06:59 PM
Rub abrasive mud particles against the finish with a soft brush? I don't know. I'd rather rinse them off while they are lubed with soapy water.
Old 02-12-10, 07:17 PM
Over the hill
urbanknight's Avatar
Quoted: 995 Post(s)
Liked 1,203 Times in 689 Posts
Even though people advise against it, I never had a problem with hosing it down and then padding it dry with an old towel. Just don't spray directly at any bearings or drivetrain parts. Lube the drivetrain afterward.
It's like riding a bicycle
urbanknight is offline
Old 02-12-10, 10:14 PM
chi-james's Avatar
Bikes: team miyata, '73 p-14, MB-3, centurion lemans, Mystery TT, mongoose atb '85
I can't agree more.
chi-james is offline
Old 02-12-10, 10:37 PM
Quoted: 7 Post(s)
I highly recommend against spraying your bike at even remotely high pressure. Bike's that people spray in order to clean are coined as "car wash bikes" in my shop. Often times, you end up getting the bike to look aesthetically pleasing, but muck up everything. I prefer a toothbrush and a rag.
DRietz is offline
Old 02-12-10, 10:42 PM
Quoted: 7 Post(s)
Also, for the wheels I use a bigger brush (think like a small broom head) on the tires. Dip it in simple green water and get the water all over the top of the tire (I do ~8in segments going from the valve hole). Scrub scrub. Sidewall/rim. Scrub. Turn wheel. Dip in simple green water. Repeat.
DRietz is offline
Narhay
Classic & Vintage
49
12-05-16 09:35 AM
Bassmanbob
Bicycle Mechanics
13
12-26-15 07:47 AM
relnix
General Cycling Discussion
22
06-11-13 03:18 PM
contango
Bicycle Mechanics
38
02-19-13 01:11 PM
rdtompki
Bicycle Mechanics
9
06-23-12 11:33 AM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
