mavic ellipse and brake
I'm thinking about getting these for my new wheel set. Is it ok to use a front brake with one of these rims? i skid for the most part but i like to have a brake for emergencies
thanks
thanks
OK? As in what sense? There are all sorts of ill-advised set-ups on this forum that are "OK" in the cosmic sense. I would not run a "nice" non-machined front with a brake, but I am sure there are others who have no issue with it. Eventually the annodizing will wear off if you actually use the brake. But you already knew that.
everyday I'm hustlin'
Bikes: Surly Crosscheck, Surly Steamrolla
I used to have a brake on my mavic ellipses. it has a little bit of a machined surface. But the paint will just wear off. it will be fine.
Bikes: surly Steamroller, Mercier Kilo TT pro
but in all non-sarcastic seriousness, you're fine.
the ellipses have a braking surface.
here's a picture of my old ellipses: https://i63.photobucket.com/albums/h1...g?t=1266099574
you can just barely see the braking surface. Man, I destroyed those wheels though. You can see tons of dents. hahaha.
thanks alot man, its good to get a solid answer
aNYthing
Did a Janky setup on my Leader.
Mavic Ellipse in the rear and a cheapo Forte Titan in the font.
The machined Titan matches up pretty well with the Ellipse, the bladed spokes and hubs look similar.
But you prolly want that all black look right?
Well youll be able to brake somewhat,
not very well in the wet and youd ruin the finish on a expensive front wheel.
Tarck bike dot com
Bikes: Fuji tarck '08
If I remember it might be a bit off but it should be fine. Most people I knew riding ellipses had outboard cranks
anyway track hubs to work with the forte rear?
that would be a sweet, since the forte wheelset i've only seen come for road bikes. if we could swap out the hub for a track one, it'd be like a budget mavic ellipse set.
Tarck bike dot com
The only track hub that would work would be a mavic hub since it's so similar. It could probably possible to use a surly fixxer tho...
According to Performance the wheelset may actually turn out to be a couple grams lighter, if not the same. Not sure of quality though especially fixed
