Shimano 600 brake, side-to-side play! (with video)
steel junkie
Hi,
I am having problems centering my Shimano 600 rear brake. One of the problems is that there is some side to side play. I cannot figure out what is causing this...
Here is a video I made.
Any ideas?
Thank you
Any ideas?
Thank you
Quoted: 2026 Post(s)
Liked 1,096 Times
Is the mounting nut tight?
steel junkie
Yes! All nuts stay in position when it goes side to side. The spring holder nut stays in place aswell.. Only the arms move..
just pokin' along
Quoted: 11 Post(s)
You might need to remove the caliper from the frame to tighten the adjusting nut on the backside of the caliper:
Go to the bottom of the Park Tool page to see the procedure:
https://www.parktool.com/repair/readhowto.asp?id=22
Bikes: '82 Giante super challange, 70 Gitane Tour de France, GT Gutterball
on an unrelated note, what kind of tires are those?
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
I am not sure but I think this is normal. (although the remedy put forth by dessertdork sounds good) the brakes arms are free to pivot on center bolt and the return spring floats to some degree. if there is alot of play in the groove where the spring rest the arms will move more. while these brakes look a little loose it does not see to be a huge ammount. do the front brake move like this?
Sugar "Kane" Kowalczyk
steel junkie
Vittorio Rubino Pro II
