Damaged Steerer?
Damaged Steerer?
Old 02-14-10, 09:56 PM
Underwhelming
MrTuner1970's Avatar
Bikes: Lynskey R330 Ti, Dean El Vado Ti, Trek 4300
Damaged Steerer?
What would you do if this was your steerer, knowing it was your life on the line?
Alpha Q carbon fork (GS-10). Flipped the stem and removed all the spacers. Tightening up the stem bolts, trying to be very careful not to over-tighten them (I don't yet have a torque wrench). Going fairly easy (so I thought) and hear not a crack, but more like a crick. Take stem and headset off to look, and see this: no crack, but there is a compression mark on the steerer tube. It looks as if it is only on the outer layer of carbon, as the attached pictures indicate.
Not having experience with this, my initial thought is that it's something that absolutely needs to be monitored, and possibly replaced just to be on the safe side. (I rode it around the neighborhood streets a few times, but haven't taken it out on a normal ride yet. The mark didn't change after the very short rides around the hood.) The compression mark looks to be 0.2 mm or so deep at most. I can afford a new fork, so that's not the issue. Would much rather replace it if there is any possibility of the steerer tube being significantly weakened by this over-tightening. Just imagining what results from a fork failure makes me ultra-queasy.
Replace or not? What say you all?
File Type: jpg
File Type: jpg
File Type: jpg
MrTuner1970 is offline
Old 02-15-10, 03:14 PM
Underwhelming
FWIW ... made contact with Alpha Q with the same email and pix. They recommended replacing the fork.
I don't know how much of that recommendation is legal CYA. But I'd rather be safe than broken up somewhere because of an accident. Ordered an Edge 2.0 fork today.
Dang, learning is expensive sometimes. But I'll never make this mistake again either. (Also ordering torque wrench today.)
Old 02-15-10, 03:35 PM
TallRider's Avatar
Quoted: 128 Post(s)
Liked 12 Times in 10 Posts
yeah, you don't wanna mess with a damaged steerer. but yours isn't NEARLY as bad as the steerer-tube that I ran across last night. And that's taking into account that yours is carbon, vs. the one I saw last night being steel.
"c" is not a unit that measures tire width
TallRider is offline
Old 02-15-10, 03:39 PM
Liked 7 Times in 6 Posts
I cracked the steer tube on my Colnago Carbon Star for because I used the torque spec shown on the stem, it was the only spec I could find. The replacement cost me $800 including a discount.
A carbon fiber steer tube does not need more than 5 nm and less is probably good enough.
Al
Al1943 is offline
Old 02-15-10, 04:36 PM
Underwhelming
Al
$800 ... Ouch!
The tech from Alpha Q said this: "Most stems including ours list a max torque spec on them. It lists the torque at which the hardware will be fatigued to the point of stripping or damage. Most specs are around 5-6Nm but most assemblies only need around half of that."
I'm thinking about maybe listing the damaged Alpha Q on eBay. Maybe some lightweight could use it. Heck, I really think it would be rideable, but at my current weight of 190 lbs., I don't want to be worrying about it on every ride. No fun if you're wondering if this is your last ride ....
Old 02-15-10, 04:50 PM
Quoted: 1109 Post(s)
Liked 1,200 Times in 760 Posts
The only thing I can say is why wouldn't you buy a $30 torque wrench before doing this? That just doesn't make sense at all.
Camilo is offline
Old 02-15-10, 05:00 PM
I agree with you but in my case the reason I broke the steer tube was because I was using a torque wrench and the torque spec on the stem. Without the torque wrench I would not have broken the tube, in this particular case. I still use the Park 1/4" drive torque wrench on stems and other small parts but with better information and lots of intuition.
Al1943 is offline
Old 02-15-10, 07:34 PM
Underwhelming
In my case, I had seen my bike mechanic adjust the headset (and retighten the stem bolts without a torque wrench). And I'd done it once before also without over-tightening (on the same steerer, last week, when I had moved two spacers). In my line of work as a piano technician, I have developed a pretty good feel for things as they tighten. Just missed it this time.
Old 02-16-10, 01:46 AM
ah, makes sense. I never owned a torque wrench until I started buying light weight parts and started seeing torque specs printed on them. Even then, I bought them partially to try to be more exact w/ tightening, partially because I like tools 8-)
Camilo is offline
Old 02-16-10, 01:55 AM
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 25 Times in 18 Posts
Pretty expensive lesson. Numbers printed on the stem doesn't mean jack ****. It can't, if you just think about it for 30 seconds.
operator is offline
jonelliotelliot
Bicycle Mechanics
20
03-28-18 12:55 PM
TeamLaVaylie
General Cycling Discussion
5
04-13-17 09:04 PM
Hapsmo911
Bicycle Mechanics
9
06-16-12 12:35 PM
nightfly
Singlespeed & Fixed Gear
18
06-02-12 06:13 AM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
