For the love of English 3 speeds...
#426
Bikes: Scott Lightflight MTB, Raleigh Sports 3 spd, Rocky Mountain Hammer, Raleigh Twenty 3 spd, Eaton's Glider 3 spd, CCM Galaxie ladies, CCM arch-frame mens missing model name, Miyata Terra Runner, numerous waggons, and various hulks begging restoratio...
[QUOTE=gna;10942226]
For online tutorials, my favorite has disappeared, but GrahamNR17 has several excellent videos on YouTube. Go to his website and click on "Technical": https://www.togglechaintour.co.uk/
Great viddiyo. My favourite line so far:
"Cause nothing coming out o' Nott'n'am by then was particularly circular."
#427
Count Orlok Member
[QUOTE=Fir;10942881]
[/QUOTE=gna;10942226]
That's a good one.
I love it when the dog farts in one of the videos.
#428
[QUOTE=gna;10943056]He has the most specific oil advice i've seen [except he says nothing about amount or frequency.] Guess i'll stop with the double virgin extra cold pressed olive oil with tarragon then. Now i'm looking for the dog one.
#429
Count Orlok Member
I use 10W30 motor oil. I bought a quart of synthetic 10W30 on sale. Lots of folks use Automatic Transmission Fluid (ATF), too.
#430
Bicycle Repair Man !!!
[QUOTE=Fir;10943460]
Problem with the tarragon infused oil is that you can't help from getting hungry on your ride, which is always a problem for me.
My rides tend to be the time spent between snacks.
#431
Czech it out
Speaking of which, Aaron mentioned something about repowering his motor and I was thinking to suggest a nice dark Czech fermentation. There's one called "Baron" (est 1466) for instance. I find it powers my bike remarkably. I just place it in the refridgerator in an obvious location. I find the bike moves much quicker and more smoothly, particularly when pointed toward home.
#433
The 3-speed hub on the $30 Raleigh Sports that I posted about recently was pretty much fubar when I bought the bike. After I took the hub out of the wheel, I overfilled it with ATF and exercised the crap out of it in all forward gears and back pedal. I thought that I was going to have to take it apart, but after messing with it for relatively brief periods over several days, and draining and re-overfilling, it started to work ok. all three gears would engage and it would "coast" properly. Eventually, it stopped leaking ATF and appeared to be fine. I built it into a new wheel and it's on the bike and it performs flawlessly. Shifts easily, coasts properly, back pedals properly -- what can I say, I'm in Sturmey Archer Nirvana. The moral of this story is, just because your 3-speed hub isn't happy right now doesn't mean it won't respond to a ltittle massaging -- even while enclosed.
#434
Quoted: 7348 Post(s)
Liked 2,464 Times
Sturmey Archer and ATF: a match made in ______________(fill in the blank).
#435
My suspicion is that the lubrication requirements of the SA 3 speed hubs are pretty easily met by any low viscosity oil that doesn't turn to tar like linseed oil or WD40 would or easily evaporate.
#436
Liked 2,464 Times
I use ATF on my chains, too. It's great.
#437
Sorry, Tom; yours was The most specific hub oil recommendation: ATF :-)
BTW, Clubman or anyone, when encountering an old CCM with no documentation, can anyone tell how to discern whether he has a one or two speed hub when he is feeling too poorly to be ridden? I read someplace that some of them had a hub that you kick backwards to shift. How you'd do that without engaging the rear wheel decelleration and tail-spin system was not described.
#438
My favourite chain lube is home brew... 1 part motor oil and three parts mineral spirits.
Best lube I have ever used.
#439
Bikes: 198? Raleigh Technium 480, 1970 Raleigh Sports, Motobecane Nomade Sprint
Since I discovered the joy of 3 speeds I've been using 3-in-1 30 weight Motor Oil. It comes in the same convenient and cheap bottle that regular 3-in-1 does but it doesn't gum up like I've heard the regular stuff does. I've had no problems so far. I also use it as chain lube.
#440
The way that the hub worked was by a very slight backwards torque. Too slight to engage the coaster brake, almost unnoticeable, but it would shift between the two gearings. I never owned one of these bicycles as they were way too expensive for us, but I did ride several owned by wealthier friends and my recollection is that they worked very, very well. My guess is that the two gears were low, and direct -- sort of like the two lower speeds on an AW hub. But that's a guess.
Probably, in addition to the colored bands there will be some sort of marking either on the hub itself or the coaster brake frame bracket which will identify the hub, though that's a guess too.
#441
When we were kids, Schwinn made a bicycle with a two speed coaster brake rear hub. To the best of my recollection, the hub was by Bendix. What visually differentiated the two speed coaster brake hub from the single speed Bendix coaster brake hub were several red bands painted on the two-speed. It is my recollection that there were grooves/indentations in the two-speed which were painted, but I never examined one sufficiently close to tell. On the net, there are some pictures of two-speed Bendix hubs with the bands painted yellow, but I remember red.
For the Bendix version, the two-speed hubs are substantially larger than the regular coaster brake hubs.
I think there were two of the two-speed models: red and yellow. One has ratios for a smaller wheel (yellow, I think). In the US, anyway, the two-speed hubs are somewhat rare (that is, you'll see a very large number of bendix coaster brake hubs for every one two-speed that you come across).
Fichtel und Sachs also made a two-speed hub (I believe these are regarded as superior).
Edit: Ah, better info here: https://www.trfindley.com/pgbndxhbs.html
Originally Posted by trfindley
The Automatic hub was made from 1960 to 1969. It was last listed in the 1970 Schwinn Catalog.
There were 3 types of Automatic Hubs, identified by band color: Red, Yellow, and Blue bands. The Red Band was made 1960-1964. The Yellow and Blue Bands were made 1965-1969.
The red and yellow band hubs have a low gear: 1 sprocket turn for .67 hub turn to go up hills easier. High gear is 1:1. The hubs would go on bikes with 26" and 24" wheels. They were also used on bikes with 20" wheels and 46-teeth sprockets. The red and yellow hubs have some different parts in them that won't interchange. Check the diagram for the different brake parts of each hub.
The blue band has 1:1 low gear, and high is overdrive: 1 sprocket turn for 1.5 hub turn. These are used on bikes with 20" wheels and 36-teeth sprockets to go further on flat roads.
#442
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,054 Times
You only back pedal a titch to make the gear change...you don't have to create any drag, at all.
#443
Thanx guise, I have two CCMs one with 28" and one with 26" round and round parts. Both have the Sachs hub. Either of them might be centennial babies, not sure. I'll just have to retyre them to find out, i expect.
Last night we took our BBF2 to the opera. It was a total tragedy, with a lot of hollaring and fighting and heaving bosoms and the young lady died untimely. (The opera that is, the bike performed admirably, the stoker exemplary.) It strikes me as a rather civilized way to get to a somewhat barbaric form of entertainment.
#444
Count Orlok Member
https://www.bunchobikes.com/auto.htm
#445
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
#446
perpetually frazzled
Bikes: 1977 Bridgestone Kabuki Super Speed; 1979 Raleigh Professional; 1983 Raleigh Rapide mixte; 1974 Peugeot UO-8; 1993 Univega Activa Trail; 1972 Raleigh Sports; 1967 Phillips; 1981 Schwinn World Tourist; 1976 Schwinn LeTour mixte; 1964 Western Flyer
Quoted: 5 Post(s)
Liked 6 Times
I'd think it'd have a detergent quality that would work very well for cleaning up the hubs. It's not too watery?
I use ATF in my Sturmeys and find that it works rather well.
Also, for the comment about WD-40, I find that with sticky hubs, if you drown it in WD-40 and ride it for 20 miles or so (shifting very often), then refill with ATF twice (to clean out the WD), it works really well to de-gunk long-sitting hubs.
#447
WD40 isn't bad for getting stuck stuff unstuck, the problem is that it leaves a residue behind as it evaporates and it is more volatile than oils, atf, etc. So, if you allow it to remain in the hub, it's not good. Using it as a flush and then flushing it with atf, or whatever, is ok, I suppose.
Apparently, the primary ingredient in WD40 is a light hydrocarbon closely related to something called Stoddard solvent which is a lot like kerosene. It's pretty much the stuff that's used in solvent cleaning systems. So, yes, like the solvent or kerosene it will dissolve gunk and "varnish" left behind by the evaporation of other oils/lubricants. You can also use ATF cut 50-50 with acetone.
#448
Count Orlok Member
Triumph of the will
Here's some before, during, and after shots of a Triumph I fixed up for my sister-in-law:
The hub was coated with varnish and filth. A pawl spring was broken, too. The parts look a little worn, but it seems to work okay. I regeared with a 22T cog, as she lives in Birmingham, Alabama.
#449
Liked 2,464 Times
Very nice job, gna! How hilly is Birmingham? More importantly, how does she like it?
#450
Count Orlok Member
Birmingham is very hilly--it's the beginning of the Appalachians--so 22T may not be big enough.
Now I have to fix up the Gentleman's Triumph for my brother, and a Lady's Sports for a friend of my wife, and the Sports Khatfull dropped off--lots of English 3-speed love.
