Bike build problems - what would you do?
I just had a bike built up by a (for now anonymous) local bike shop. They have a good reputation, but I've not used them before.
Took it out for the first time and found two problems:
1) The rear skewer was loose by almost a full turn – I discovered this as I pushed off; the wheel pulled into the stays and I ground to a halt. Good job I wasn't on my downhill start as this might not have happened immediately, but at 40mph in traffic.
2) The cassette had not been tightened. When I handed over the components, I told them I'd put it on by hand, but the mechanic said he'd make a note and that the bike would be tested anyway.
Needless to say, I was mad , but the shop is closed, so I fired off an email asking for an explanation.
Maybe they'll come back very apologetic, but how would you feel and what would you do in this situation?
Bikes: '07 Trek 520, '09 Gary Fisher Triton, '04 Trek 8000, '85 Trek 500, '84 Trek 610, '85 Trek 510, '88 Trek 660, '92 Trek 930, Trek Multitrack 700
Quoted: 19 Post(s)
What would I do:
1. Tighten the skewer
2. Tighten the cassette lock ring.
3. Check the rest of the bike.
4. Ride.
4. Ride.
"When I hear another express an opinion, which is not mine, I say to myself, He has a right to his opinion, as I to mine; why should I question it. His error does me no injury, and shall I become a Don Quixot to bring all men by force of argument, to one opinion? If a fact be misstated, it is probable he is gratified by a belief of it, and I have no right to deprive him of the gratification."
T. Jefferson
T. Jefferson
2 - I have to buy a Campy nut (I only have a Shimano)... having spent £60.00 on the build, I don't think so.
4 - You'd just laugh it off and forget about the fact that it could have killed you?
Bike addict, dreamer
Quoted: 5 Post(s)
Liked 11 Times
I buy & sell bikes for hobby money. Have a lot of experience doing this. Every bike gets ridden to the beach & back. It's about a 15 mile ride. Every bike needs a little something tightened or adjusted by the time I get back. But they all feel fine after the first quick spin around the block. Sounds like yours didn't get a proper test ride.
I only trust me to check out my bike. It's part of the pre-ride routine; so loose stuff would not have endangered me.
A loose nut is an opportunity to buy a tool. After a while, you'll have a full set.
It's a sad reflection on bike shop mechanics if the only person you can trust to do a job properly is yourself. I normally do the pre-ride routine, but fresh from the workshop, I kinda imagined that everything might be screwed down right. Silly of me...
Oh well, I guess mechanics get paid peanuts and they don't call them grease monkeys for nothing. (With apologies to every self-respecting mechanic out there - you're all getting tarred with the same brush I'm afraid.)
Don't Believe the Hype
Bikes: 1999 Steelman SR525, 2002 Lightspeed Ultimate, 1988 Trek 830, 2008 Scott Addict
Quoted: 21 Post(s)
I always go over what I had the shop do point by point so I know it was done.
Hmm, not very often I have tighten up very much after a test ride, or after WEEKS of riding.
And I've NEVER had to re-snug a cassette lockring. They're tight when I install, and they're tight when I change them. Full turn on a skewer? Sloppy work.
My present bike is a frame-up build; ONE TIME, I had a barely loose skewer, took the 10 seconds to fix it and went on.
I can't blame anyone for any problems I encounter; I built it, I have to take it. NOBODY has ever worked on my bike for me. (Yup, control freak when it comes to the bike)
Quoted: 1572 Post(s)
Liked 643 Times
Until I was able to come up with an answer, I wouldn't open up the topic. Rants might make you feel assertive, but they seldom accomplish very much. Once I had figured out what I thought would be equitable, I'd just ask for it: "I think you owe me a couple of free inner tubes because you didn't tighten the cassette when you built my bike and I almost crashed because of it."
Second, why install anything loosely? Either install the cassette properly or leave it off. That would have eliminated the opportunity for the error.
