Saddle selection: Track vs Road
It took me two years and at least a dozen models to find the perfect saddle for my ride bike. I was having trouble with the usual suspects, saddle sores and numbness, but found the solution in the Specialized Romin. I'm just getting into track racing and am wondering if I should use the same saddle, or go with something else considering the different bike fit, positioning and length of ride time. Any suggestions?
monster
Quoted: 12 Post(s)
I would think that if the Specialized Romin is working for you on your road bike it work equally well on a track bike. I run the same saddle on my track & road bike and my butt is happy.
Bikes: 1975 Albert Eisentraut, 1992 Bill Davidson, 2006 Moots Compact, 2007 KHS Solo-One, 2010 Van Dessel Drag Strip Courage, 2013 Alchemy Xanthus, 2016 Breadwinner Lolo, 2018 Moots VaMoots RSL, 2019 Chapter2 Tere Disc, 2020 Chapter2 Ao Limited Edition
Quoted: 31 Post(s)
Liked 32 Times
I use a Specialized Toupe on my road and track bikes. You will spend more time riding on the "rivet" (nose) on the track bike than your road bike.
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
There is no difference. If anything, you will have less saddle issues in general as most races only last between 5-15 minutes or so.
Stick with what you know works...until you start using aerobars in time trials. Then you have to start all over again
AmahlAmahlAmahl
Track Cycling: Velodrome Racing and Training Area
25
10-08-19 05:32 PM
Martyn333
9
01-01-13 05:55 AM
seejohnbike
4
10-13-10 01:27 AM
