the elusive bootie
Bikes: '08 Kona JTS & Riviera (?) Sport converted Fixed Gear
the elusive bootie
Hi Folks,
My feet are always cold, and I've never quite found a booties that does the trick. I did some online research, and found the "Pro Endure H2O" has received rave reviews. But I can't find it online anywhere!
Anyone know about this bootie? And are there any other cool-footers like me out there? What booties do you recommend?
thanks
thanks
on second thought, this should probably be in the winter cycling forum. Oh well.
Bikes: Specialized Allez, Specialized Sirrus
Quoted: 17 Post(s)
Your wish is my command. Moving to Winter Cycling.
smitten by саша
Bikes: Salsa La Cruz with Rohloff; mutt parts
i know a lot of this depends on conditions and time outside; for my needs, the Pearl-Izumi Amfib pros, with some extra silicone spray, over my touring shoes (and not overly snug in fit), with some quality wool socks, did it for me. my conditions? 1 hour, coldest was -10°F (by the end of that ride my feet were "cool" but nothing worse than walking). however, i would not attempt a century in those mid-state NY conditions with my old set up. some might be braver, but not i.
others in extreme temps swear by big boots and flat pedals. for the real cold, i think that might be the only way go, since any bootie over a clipless shoe is basically a shoe with a vent hole in the bottom (although i have also seen some mods of this, e.g., an extra plate above the cleat).
Formerly Known as Newbie
In colder temps cleat is a heat sink. Adding layers on top of the shoe will not address that problem. You'll also need more insulation between your feet and cleat. For me, this was one of the reasons to move to platform pedals and "real" winter boots, years ago. YMMV.
To err is human. To moo is bovine.
Who is this General Failure anyway, and why is he reading my drive?
Become a Registered Member in Bike Forums
Community guidelines
Plays in traffic
Bikes: 1996 Litespeed Classic, 2006 Trek Portland, 2013 Ribble Winter/Audax, 2016 Giant Talon 4
Quoted: 76 Post(s)
Liked 14 Times
This is why winter cycling boots, like the Lake MXZ302, have an insulated mid-sole and insulated insoles. You get to keep the heat and the clipless.
To the OP: You'll note that the review you linked to raves about the water resistance and says nothing at all about warmth. Dry means dry, not necessarily warm. Are you reading too much into the reviews?
Keep in mind too that for most reviewers, 50°F, 10°C is considered cold. They ride the trainer when temps dip below that.
In northern climes, there's not much you can do to convert shoes designed to keep your feet ventilated and cool into something to keep them warm. Booties help, but in my experience, only to around 5°C. Below that, I need shoes designed to keep my feet warm, instead of shoes designed to keep my feet cool.
Finally, tight-fitting shoes, as roadies are encouraged to wear, can restrict blood flow and the accompanying warmth. You may find that all you need for warm feet are shoes that fit more loosely and let blood flow normally.
New shoes aren't practical, because I want booties for Road + Mtb riding and two new pairs of shoes is not in my budget unfortunately
Are cleats really a heat sink even at freezing?
Yup
Location: where the sunbeams end and the starlight begins
Bikes: Kona Unit, planet X cx bike, khs fixed gear
Quoted: 9 Post(s)
Liked 6 Times
Yes, but not too bad. To -5C I ride my winter shoes with felt insoles and midweight wool socks from mec, below that i switch to thiner insoles and heavyduty wool hunting socks from basspro that come upto my knees. Basspro rocks for woolsocks. Extreme cold -20C I wear hunting boots with felt soles, think woolsocks and switch to platforms and powergrips. I made my own for $15 as buying 2 sets was too much for me.
When sadness fills my days
It's time to turn away
And then tomorrow's dreams
Become reality to me
This review is in a UK website. In the UK, wet is the problem, -5C is a very cold day. At -10C everything stops. People still riding their bikes would risk incarceration at the nearest Mental health facility. MEC's simple packcloth overshoes while looking terrible in comparison, would probably give similar insulating properties.
Single-serving poster
Larger shoe, larger oversock... The MEC overshoes are actually fine, not too hip and provide no insulation but you will stay dry. Anyways, using the cold shoe as an insulating layer is doing it backwards which is why booties aren't as warm as an overshoe and shoes which can accomdate larger socks without cutting off your circulation. Another bootie discussion to browse. You will also want to cover your ankle with something because cold ankles mean cold feet... again heavier socks work here.
I will also vouch for cleats sucking heat out of your sole(soul?), it is not so much the cleat as it is the cleat and the pedal... spd i bet would transfer heat faster since your cleat is in contact with a large cold steel pedal, while eggbeaters wouldn't be as bad since it is only two steel springs. I haven't tried my hypothesis out though.
Quoted: 5223 Post(s)
Liked 3,579 Times
chemical toe or hand warmers fixed my problem
Soma Lover
Bikes: one bike for every day of the week
Nothing less has ever worked well for me below -5C. With winter boots and Powergrips I threaten clipless for efficiency and can ride all the way down to about -20C but watering eyes and fogging eyewear effectively limit me to -10C. I suspect a dedicated winter cycling shoe would do just as well but 90% of my winter riding is commuting and they're just too garish to wear at work. I'd rather deal with the Powergrips than bring a second pair of shoes.
I found wearing Sealskinz over a Smartwool snowboard sock works better than a shoe cover for keeping my ankles warm when I'm still in the clipless temps but I also have a pair of Lake MX255 shoes with waterproof uppers that were intentionally purchased a full size large to accomodate such an arrangement. They really make the amount of heat lost through the cleat obvious in spite of two pair of socks and the Superfeet Red Hot insoles they've been set up with.
I absolutely hate dealing with shoe covers for anything remotely resembling a commute. You look like a total Fred walking around in the grocery store in them and pulling them on and off is a major headache. They only get pulled out for cyclocross, snow and ice biking, and late/early season distance work on the the roadie bike.
+1 for winter boots and flat pedals. Works for me in New England. Occasionally I have to push or walk the bike in the snow. I use low sorrel winter boots good to -25 F, why try to reinvent the wheel. They work good for walking around too.
Shuckin' and Jivin'
Bikes: Giant OCR3
I use these even though they're for Mountain bikers, they work fine with my road shoes.
https://roll-online.com/product/pearl...rs-58165-1.htm
haha true, I have been reading a lot of reviews, but I thought it said somewhere it was good for up to 0C or thereabouts. I don't plan on doing much riding under freezing temps, but my feet get cold easily so I was looking for something in the zero range and waterproof is an added bonus. Also, I'm moving to the Rockies for a year (SW Alberta) and I've heard the weather can be unpredictable, including raining on a dime.
I would recommend getting a pair of winter mountain bike shoes and some good shoe covers. Ride the mountain bike when it's really cold and when it's cool but not too cold ride the road bike with the shoe covers on.
Quoted: 52 Post(s)
Liked 17 Times
Pedaled too far.
Quoted: 11 Post(s)
Liked 7 Times
My attempts this winter failed. Systems that had worked okay in previous warmer winters where my commute was 1/3 the length that it is now, didn't work this year, and I got tired of blue feet that took a hour in a heating pad to thaw out.
I commute on a recumbent, which I think made the problem worse. I need a solution that is good down to about 15 degrees F. I'm guessing that heavy boots and thick socks are the way to go. The circulation on my feet isn't very good, so spot fixes like warmers I suspect won't work well. I need to start with warm feet and keep them that way.
"He who serves all, best serves himself" Jack London
hilltowner
Touring
22
02-07-16 06:24 PM
