Disc wheel for 110 spaced frame.
Old 03-09-10 | 12:45 AM
poppawheelie
Bikes: Panasonic, Super Cycle
I posted this in the track cycling section as well but was refered to post it here.
I have been looking around for disc options for my frame which has 110mm spacing. I haven't been able to find anything other than 120. In Osaka the LBS told me I could use an axel conversion kit but it would only cut the difference down by 5 or 6mm or so. I don't want to stretch my frame even if it is only 5mm. I haven't been able to find anything via search, just 110 hub discussions and a lot of stem discussions.
Any suggestions other than not using a rear disc? I was hoping I could find an older HED with this spacing but no luck as of yet.
Thanks
milkcratebasket is offline
Reply
Old 03-09-10 | 12:49 AM
Kimmo's Avatar
That's only 2.5mm a side... why not, exactly?
Kimmo is offline
Reply
Old 03-09-10 | 02:28 AM
Exit.'s Avatar
No lugs? No hugs.
Bikes: '85 Miyata 310, '06 GT Performer
110mm spacing is NJS spacing, and NJS doesn't allow disc wheels. ergo, it's unlikely anyone has ever bothered making a 110mm disc wheel.
Exit. is offline
Reply
Old 03-09-10 | 09:19 AM
miamijim's Avatar
Sheldon Brown Memorial - Donating
20 Anniversary
Its all relative to the type of hub. Some hubs can easily be narrowed by 5mm per side while others cannot. If the wheel has wide hubs flanges you may NOT be able to remove 5mm from the drive side without the lockring hitting the frame.
miamijim is offline
Reply
Old 03-09-10 | 10:44 AM
poppawheelie
Its an NJS spacing now but I read that in general track frames used to be spaced at 110. Hence my post here. I don't want to stretch the frame for the same reason I wouldn't wear a pair of shoes a size down. I can't imagine it being very god for the frame. I will continue my search!
Reply
Old 03-09-10 | 12:10 PM
PDXaero's Avatar
French threaded
Bikes: many
When they were generally spaced 110, disc wheels didn't exist.
When was the first disc wheel? Early 80s maybe late 70s? Even then they weren't specifically for track.
PDXaero is offline
Reply
joe@vwvortex
Tandem Cycling
7
08-10-14 10:39 PM
dr1445
Bicycle Mechanics
7
10-21-13 06:10 AM
mrgrunt99
Mountain Biking
0
11-30-11 11:40 AM
|3iker
Bicycle Mechanics
8
11-20-10 10:29 PM
milkcratebasket
Track Cycling: Velodrome Racing and Training Area
9
03-17-10 04:45 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
