CO2 Pressure
CO2 Pressure
I had a flat. Replaced the tube and blew it up with a CO2 pump. How long can I expect the gas to hold the tire up in 90 deree heat?
Thank you in advace for your help.
Quoted: 1572 Post(s)
Liked 643 Times
Maybe 12 hours or so. If you're planning to ride tomorrow, you'll be pumping that tire up again.
You might have to find a chemist of physicist to explain it fully, but as I understand it the concentration of co2 in the air is lower than the concentration in the tire so the co2 migrates through the inner tube trying to correct the imbalance.
